rear LCAs and Torque arm, Front LCA bushings
Old Mar 2, 2002 | 09:01 AM
camaro6spd's Avatar
what are a good pair of LCA for the steet, anyone know how good the Lakewood ones are.....$82.99 in jegs and how much does an aftermarket torque arm do? Also how much do poly front control arm bushes improve performace, i would think that mine would be worn with 130,000 miles, also do they increase noise...if so how much?
Old Mar 2, 2002 | 03:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have the Lakewoods, they work fine.
I also have the Spohn torque arm. Installing it felt like taking a giant rubber band out of somewhere in the drivetrain. I highly recommend it.
If you are serious about upgrading your suspension, the single biggest bang for the buck mod is a pair of LCA lowering brackets. These cars come with poorly designed geometry from the factory, which is what causes them to wheel-hop so bad, and lowering them makes it intolerable. THe brackets fix that. Those are also available from Spohn.
Order of priority: brackets first, LCAs second, TA third.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
TheExaminer
Aug 25, 2015 07:34 PM
NBrehm
Aug 5, 2015 07:57 PM
