??? about installing ES front control arm bushings??????????
Old Mar 5, 2002 | 12:58 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I have new Energy Suspension front control arm Bushings. The directions they come with are all messed up and cant read them.
They come assembled with the bushing and sleave already in the shell. Do I need to push the sleave and bushing back out of the shell to put the grease on them?
I know i have to have them pressed in at a shop. I just want to have back up instructions since the ones Es gave me are unreadable and I dont want some idiot at a shop to mess them up somehow. Thanks
Old Mar 5, 2002 | 09:03 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
I believe you just take the sleeve out and lube that its really all that moves once installed
Old Mar 5, 2002 | 11:42 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I took them apart complety. Just take the a-arms in with just the sleeves when you get them back lube everything up real good and reinstall. They come lubed already but it's not a whole lot on there. You don't want those anoying sqeeks to develop especially on the front a-arms, cause as you already know they are a bit ch to get off.
Old Mar 6, 2002 | 06:33 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey there John. I have a set waiting to go into my Iroc too. I understand that, yes, you do have to take the sleeve out of the bushing, lube it up, and stick it back in. Also, here's a trick I was told. Put the bushing in the freezer for a day b4 you install it into the shell. It will shrink a bit and go in easier and so will the sleeve. Also, which shop is putting your shells in ?
Let me know if you need a hand with the install and rebuild. I'm off until Monday night and would love to practice on another car before I do my own...that way we break YOUR stuff
Gimme a call if you want...803.396.5693
Ed
Old Mar 6, 2002 | 05:45 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
you can try the freezer trick if you like but there is really no need to. As long as you lube them up good they will slide right in.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
