Installed spring and having problems
Old Mar 6, 2002 | 12:00 AM
Pro91's Avatar
my car was lowered and i swapped them with stock camaro springs.... after i installed them the wheel well gap is enormous.... is there a certain spot that the bottom of the coil has to be?....
Old Mar 6, 2002 | 12:07 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Are you saying that you origanally had lowering springs installed and now you have replaced them with stock springs? Yes there is a certain way the spring sits in the lower a-arm, it's shaped to fit the curve of the spring. You may have mounted them in there wrong, this could explain the extra gap you have. Should be an easy fix if this is your problem, just compress it some and you should beable to rotate it with a little force into the correct position.
Old Mar 6, 2002 | 12:14 AM
Pro91's Avatar
i switched because my car was on 17's and now i bought a set of 15" welds with a big tire in back and skinnies up front..... so by looking at the lower a arm i can see how its shaped for the coil?
Old Mar 6, 2002 | 12:27 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Yes there's only one way for that spring to sit in the a-arm. If it wasn't something you knew about before then you probably over looked it. Now that you know about it you can't miss it.
rocn7roc
Sep 21, 2021 02:16 PM
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
