Drum cylinder frozen?
Old Mar 7, 2002 | 04:37 PM
Luke's Avatar
Car: '86 Camaro
Engine: 2.8 MPFI
Im not sure what to look for, if this is the case. But ive noticed as of late that when I brake (hard especialy) to much weight seems to be shifting to the front of the car. As a result it seems harder to stop. Yesterday for example a could barly stop sort for a yellow when i was only going like 45mph. I just replaced the rotors and pad in Nov. so I focused my atention to the drums. ...pulled the wheels of cleaned the dust... everything looked ok...still have some wear to spare before the rivets on the shoes. The cylinder on the driver side, however, cought my eye. there are 2 silver rodes coming out of each end...one rod was extended out from the cylider, as where the rod on the other side was not. It seemed to be fully submerged into the cylinder and that shoe seemed to have less wear. The passenger side is not like that. The rods are extended in equal distance. Am I seeing as frozen wheel cylinder? And could this be the cause of poor stoping?
Old Apr 2, 2002 | 10:08 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Luke
You and I probably need to do the same thing, which is to rebuild the rear wheel cylinders. Mine arent working very well if at all. I've put 25,000 miles on the car since I bought it used and the rear shoes still look pretty thick and new. Rebuilding isn't to hard, just a pain in the... the kits with the new seals are only a couple bucks.
92projectcamaro
Dec 8, 2015 12:25 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
