How to mount a trailer hitch ?
Old Mar 11, 2002 | 08:58 AM
qazd's Avatar
How would i go about mounting a trailer hitch, and other mods i might need for towing a light jet-ski? my father suggested air-bag suspension for the rear, new LCAs, and spohn SFCs, anny suggestions?
Old Mar 11, 2002 | 04:15 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
If you have a light jet ski, then no suspension mods are necessary. I occasionally pull my '88 Kawi 550 stand-up, on a single ski trailer, with my GTA and I can't even tell it's back there.
I have an Eckhardt hitch that's bolted to the rear bumper brackets and also welded to the rear sub-frame. I wanted to do a hide-away style hitch but there's no room to do it on our cars.
I wouldn't go pulling dual Sea Do's or anything like that. As long as the load is light you shouldn't have any trouble.
Old Mar 11, 2002 | 06:41 PM
89blackbird's Avatar
When I bought my 89 GTA it had a nice bolt on hitch which bolts to the rear frame where the rear bumper mounts. I still have it and if you are interested I will sell it for 25.00 plus shipping. It is fairly heavy. I will check on shipping if you want it. Comes with bolts and backing plates. The guy I got the car from towed a bike with the car. It did have air bags which I took out.I do not think they did much. jbender3@nycap.rr.com
Old Mar 11, 2002 | 06:42 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I also have a trailer hitch on my 90 RS convertible. I've pulled my small Hilo travel trailer which weighs around 2000 lbs (similar to a tent trailer) and 2 Yamaha Wave Venture 3-person sit-down style PWC's (dry weight 510 lbs ea.). Mine was made by Draw-Tite. It is called their Sportframe model #24001. I prefer it to the one Bret has because it is somewhat less visible when not in use. His has a small square receiver vs. a lower profile rectangle of the Draw-Tite. Either one will require no modification to install. However mine states it won't fit 91 & later Firebirds with the sport appearance package. As my springs & shocks aged I noticed it would bottom out the suspension more than before. If pulling 2 PWC's air shocks or air bags wouldn't be a bad idea. Just don't exceed the 2,000 lb trailer weight and 200 lb tongue weight. I haven't towed anything with the RS since I replaced the stock shocks & springs with Bilsteins & Eibach Pro-Kit. Good luck, Lon.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
