aluminum rear drums grinding when am cruising along
Old Mar 13, 2002 | 08:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
and the grinding noises stop when brakes are applied,
i replaced the front pads today and took care of them,
now to the rears,
i tried getting the damn drums off but they are super glued to the shafts,
so how am i gonna get them off so i can replace shoes or adjust them out ?
thanks for anything
Old Mar 14, 2002 | 07:06 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
Never tried this, but I heard it works. Get a small sledge and whack the part of the axle that drum is centered on.
Old Mar 14, 2002 | 12:17 PM
slowV8berlinetta's Avatar
use a decent sized hammer(preferably a rubber mallet because of aluminum), and whack the drum. Be careful not to hit the wheel studs. Your problem may also be a groove worn into outermost edge of the drum. in that case, you'll have to back off the adjusters. If that's the case, it'll be a lot more to explain, and a lot easier for someone to show you.
Old Mar 14, 2002 | 12:56 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
hope the drums arent expensive...... 9.5" ring gear aluminum drums.,,
thanks for the info ! figured id have to fight em to get em off, hmmmmm lots of pb blaster and praying,,
jaridjohn
Jul 8, 2024 03:49 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
z28addict8490
Aug 7, 2015 08:48 PM
