Sway Bar End Links
Old Mar 21, 2002 | 09:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Sway Bar End Links
i am looking to buy new end links for my front and rear anti-sway bars. i measured the sleeve and it is 2 1/4". in jegs they dont sell 2 1/4" the closests ones are 2 5/8". anybody know where i can get 2 1/4" poly sway bar end links?
thanks
Old Mar 21, 2002 | 09:28 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Energy Suspension's website lists 2" and 2 3/8", no 2 1/4" listed. If you have to have it 2 1/4", get the 2 3/8" and lop you off 1/8" with a hacksaw.
http://www.energysuspension.com/endl.html
Old Mar 21, 2002 | 09:48 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
Contact Bob at Guldstrand for the poly end link kit.
These folks know about the F-Body, especially the 3rd Gen.
I just picked mine up at their shop while on travel in Calif. Price is right, too.
Tell him Mike from Maryland says hello.
Old Mar 22, 2002 | 09:48 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
I haven't used them but Pep Boys sell's a set of red poly bushings with HD washers for $9.99 or the whole end link for $14.99 Has anyone tried them ?
Old Mar 22, 2002 | 10:38 AM
KeithO's Avatar
I simply went to my local NAPA shop and they gave me a polyurethane set that fit perfectly. No problem, no issue...
Check napaonline.com to see what part they will try to give you. I can't imagine this being a rare part.
Old Mar 22, 2002 | 08:29 PM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
I GOT THE RED ONES FROM PEP BOYS AND I HAVE NO COMPLAINTS
Old Mar 22, 2002 | 08:47 PM
1991Z28's Avatar
I ordered them from Jegs...Requested the 2 1/4" (twice) and they sent me the 2 5/8"...I guess atleast they can be cut down, but I think when I do, the bolt will have to be replaced with a shorter one because the threads are on the end of the bolt, not the whole length.
Old Mar 23, 2002 | 12:50 PM
Changa2's Avatar
Just now dropped my front Sway Bar (87 SC). The Links do measure 2 1/4" and I have on the bench ES 2 5/8", from JEGS.
I'm re-installing a 32mm Z28 Bar and am inclined to just go ahead and use the 2 5/8" Link (only 3/8" longer) w/o cutting it.
Is this a mistake?
Old Mar 23, 2002 | 04:29 PM
1991Z28's Avatar
Can't say for sure, but probably. It would definitely throw off the geometry of the sway bar, but I'm not sure if it'd really matter. You figure the endlinks are there to lift and pull on the ends of the sway bar. This, in turn, creates a twist in the center section of the bar (where it's mounted to the frame). I don't really see how that twist would be affected by using slightly longer or shorter end links, but personally, I think I'll just keep it same as factory--changing them shouldn't improve performance. Maybe it'd just wear the end link bushings faster?????
Old Mar 23, 2002 | 04:54 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Just picked up a set at Advanced Auto parts this morning. PN 18203HD (TRW), this is a poly end link kit only 5.92 each.
Old Mar 23, 2002 | 05:23 PM
Changa2's Avatar
Thanks for your responce. I finished it without timming the sleeve and going down the road I don't see any problem. I do want to check for any frame interferece though
Old Mar 23, 2002 | 06:05 PM
89blackbird's Avatar
Most good people who set up road race cars will tell you your rear sway bar ends should be parallel to the ground. To answer the next qestion they where not when stock. On a street car I do not believe you will see a difference. If it was a Bush car you would be in the wall.
Old Mar 24, 2002 | 07:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Should anyone be interested in a 1LE hollow 36 mm front sway, please see my ad in the classifieds.
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
