Is there any way to...
Old Mar 26, 2002 | 06:47 AM
LottaBallsCamaro's Avatar
put a bigger master cylinder then the original on???
Old Mar 26, 2002 | 04:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What kind of car? The J65 (4 wheel disc, 82-88) master cylinder has a larger bore than the J50 (disc/drum for 82-88, then used for all brake systems in 89-up). This translates to a "harder" pedal effort.
Old Mar 28, 2002 | 10:47 PM
It is an 87 IROC with 4WD. Would an A or G body car have a bigger master clyinder? Would it work with our cars?
Old Mar 28, 2002 | 11:45 PM
Momar's Avatar
An 87 IROC with 4 wheel drive.... hmm interesting
J/K
Ben
Old Mar 29, 2002 | 04:54 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Why do you want a bigger master cylinder?
Old Mar 29, 2002 | 12:10 PM
MrsLottaBallsCamaro's Avatar
We're thinking that the master cylinder is what is causing our IROC to have such spongy brakes. Maybe if we could put a bigger one on there, it would brake better.
Old Mar 30, 2002 | 12:52 AM
Almost every brake part on the Camaro is below par. I figure if I'm going to replace the master clyinder then I might as well(there goes that phrase again) put a bigger one on there. I bigger MC would be able to apply more pressure right??
Old Mar 30, 2002 | 05:17 AM
ANDYZ28's Avatar
Car: 1982 Z-28
No, the properties of hydaulics are inverse. A smaller master cylinder bore/piston will exert more pressure.
At one time GM had issued a "TSB"on the 4 wheel disc brakes on the F-bodies. It stated " that if the customer objected to the firm pedal of the brake system. That they are to install a different master cylinder Part# so-and-so. This replacement master cyliner simply had a larger bore.
Rear my post and all the links about the 1LE upgrade. Their is a lot of good info in there about this subject.
Thanx,ANDYZ28
DuronClocker
Oct 25, 2004 03:06 PM
3rdGenSS
Aug 25, 2004 05:12 PM
Maverick H1L
Aug 10, 2004 12:34 PM
TheGreatJ
Jul 21, 2004 06:13 PM
Demon Z28
Pacific Northwest Region
32
Jun 25, 2001 08:05 PM
