Hypothetical rear disk conversion questions....
Old Mar 31, 2002 | 02:21 AM
BlakCamZ28's Avatar
Now I know that you are supposed to change the master cylinder and proportioning valves when you do a rear disc conversion. First thing does anyone know the part numbers for these two?
Also my main question is what will happen if I don't switch the proportioning valve and master cylinder? Will the brakes be really weak?
Old Mar 31, 2002 | 08:57 PM
bryanwhite's Avatar
The only difference I believe, is that the drum brake proportioning valve uses or applies more % of pressure to the rear than the disc brake one would. This could be fixed by adding an adjustable proportioning valve in line. I don't know about the master cylinder though.
Hope this helps
Old Apr 1, 2002 | 02:20 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I just swaped to the smaller rear disk off a 83 fireturd on my monte and have the drum proprotioning valve and mastercylinder still in place. You will have NO rear brake pressure. The darn thing left 2 big ole black marks outta my garage cause the choke was on and made the car power brake itself without the rear brakes. You'll need to get a disk proportioning valve or an aftermarket adjustable one. From what i have read on this board you don't have to swap master cylinders, in fact GM quit using 2 dfferent ones in the later 80's and just used the drum mc. Hope this helps.
Ohh yeah if you wanna know how i got the disk to work on my 9" let me know and i'll post a new thread.
hectre13
Dec 11, 2023 08:14 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Warlocksirix
Sep 3, 2015 12:26 PM
lt1z350
Aug 28, 2015 05:57 AM
stalkier
Aug 13, 2015 12:59 PM
