Install relocation brakets after SFCs???
Old Apr 1, 2002 | 12:54 AM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
Finally got my order of Spohn SFCs...want to install them this coming week....my queston...can I go ahead and have them installed and welded in place...then later on buy the lca relocation brakets and put them in place and weld them in...or do I have to do those before I install the SFCs???? I believe the SFC goes in the same place that the brackets go...but Im not exactly sure how they both go in relationship to each other....if i HAVE to...i'll order the brackets and wait to have them put in...but i'd RATHER install the SFCs and later go and install the brackets.
And Im a bit confused...do the brackets go on the end of the lca that connects to the rear...or to the frame? If they go on the rear itself...can they be transferred to a new rear...or do I have to buy another pair of brackets?
Old Apr 1, 2002 | 01:16 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
SFC's then Relo's
The way I understand it (i'm waiting to install both) is that it wouldn't matter which is first...
I know thw LCA relocations brackets go on the axle tube side of the LCA's so no problem running into the SFC's on the other end...
unless I'm missing something major here
Old Apr 1, 2002 | 12:41 PM
82camaro's Avatar
Car: 82 camaro SC
BumpaD82, you're correct. The LCA relocation brackets go on the axle mount(rear of the control arm). They don't interfere with the Subframe connectors.
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
