Changing Rear Disc Brakes.
Old Apr 1, 2002 | 04:55 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
Ok,
I have been kicking around this in my head for awhile and I know I have to do it sometime...
How hard is it to remove the rear disc brake pads on my Camaro? I need to replace the rear pads because to the best of my knowledge they have never been replaced. I have been told that changing the rear brakes is a nightmare and requires special tools...something to do with the E-Brake and all that? Oh yeah, my E-Brake is stuck as well...will not pull up on the handle.
I haven't tackled this project yet but I would like to get some guidance before I start.
Old Apr 2, 2002 | 07:20 AM
87ROCZ's Avatar
ttt
17 reads and nobody can help me out??
Old Apr 2, 2002 | 09:53 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... that's probably 'cause it is sort of a pain to do.
Do a search regarding the rear disc TSB on the early 3rd gen rear discs (pre '88).
The pistons would get stuck in the bores, the e-brake ratchet mechanism is a b!tch and they can be a pain to remove just 'cause of rust and lack of use.
Old Apr 2, 2002 | 06:50 PM
87ROCZ's Avatar
I don't think the pistons are stuck
Cuz I know my rear brakes work fine.... guess I will have to just pull the wheel and roll up my sleeves
Old Apr 2, 2002 | 06:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The Haynes 82-92 Camaro (or 82-92 Firebird) manual gives you the exact details needed to replace your rear pads. You will need to remove the rearmost lower control arm bolt on the passenger side, because otherwise, you can't get one of the rear caliper mounting bolts out. Spray all your lines down with penetrant for a few weeks before doing the job. You actually have to disconnect the brake line for the driver's side rear, there's no hose on that caliper. If the fitting rusts to the brake line, as you turn the fitting to loosen it, it'll turn the tubing, and snap the tubing off. Pep Boys sells replacement tubing, but you'll have to bend it yourself. (I bought a $3 bender from Pep Boys.) The tubing you'd want for your '87 would have metric fittings, and in Pep Boys' rack, they're labeled as being for Foreign cars, and the fittings are color-coded blue.
Old Apr 2, 2002 | 07:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Unless you have relocation brackets.
Old Apr 3, 2002 | 12:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh, so you want to play That way, eh? Well, I can change all my plugs easily with just a ratchet, 8" extension, and spark plug socket from the TOP of my V6 engine bay! So There!
(Yeah, yeah, I know, lame...)
Old Apr 3, 2002 | 06:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Probably not as easily as I can change all 8 of my plugs from the top with just a spark plug socket and a wrench.
Old Apr 4, 2002 | 10:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, I only have to change 6 plugs instead of 8!
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
