Coiled wire around brake lines
Old Apr 2, 2002 | 10:55 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
What is the deal with that wire? Does it just prevent the line from rubbing agaist something so it doesn't burst? Is it really all that important?
Old Apr 2, 2002 | 11:05 PM
turningfast's Avatar
I think it serves two purposes, one as you said for rubbing ad vibration. The second is incase if it is handled rughly and bent, it won't kink as easily because the wire wrapped around it won't let it flatten out easily.
Old Apr 2, 2002 | 11:32 PM
86IROCZ's Avatar
I thought it was to dissipate the heat in the brake fluid.
:lala:
Old Apr 3, 2002 | 05:26 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
it's purpose is to provide physical protection to the brake line. All prebent lines on our cars have this feature.
Old Apr 3, 2002 | 12:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've heard the same thing that Andy has. And it kinda pisses me off that you can't find pre-bent lines with that sheild on it. I guess we have to make them ourselves out of SS wire? Man, what a pain...
Old Apr 3, 2002 | 05:32 PM
ANDYZ28's Avatar
Car: 1982 Z-28
I have the solution to this problem. I have prebent stainless steel brake lines with the spiral wrap. I have had them custom made for me. As of now I only have the prebent lines for the disc-to-drum conversion. I have stainless flex lines too.
Getting these lines correct so that they will actually "bolt on" has always pissed me off too. So I went to the trouble of having them custom made. Then fitting them, them sending them back till I got it right. They now bolt on as if they were made at the factory production line. They fit perfectly.
If you are interested let me know. I have several sets of these.
Thanx,ANDYZ28
Reddeath210
Oct 6, 2015 08:20 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
