questions bout adjusting spohn LCA'S
Old Apr 7, 2002 | 01:07 PM
2ponchos's Avatar
i just got done putting the relocation brackets on and the lca's adj. type also the panhard bar.. the job wasnt to bad once the stock bolts were out had to torch two of them!! my question now is the parts come in stock length.. and i put the lca in the bottom hole on the bracket.. so which way do i adjust to make my car hook more?? and what is the easiest way to do it?? thanks for the help!!
Old Apr 7, 2002 | 08:20 PM
2ponchos's Avatar
anyone?????
Old Apr 7, 2002 | 11:26 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
when i did mine, i just messured, and got the wheels centered front to back, and left to right. i don't know if it is "the best" for traction, but with the additions of the brackets, you should hook up SO much better than before.
Old Apr 7, 2002 | 11:58 PM
turningfast's Avatar
The way to adjust them to hook better is in the pinion angle. I think that between 4-6* negative (pinion pointin towards the ground) is the best tohook the car up.
Old Apr 8, 2002 | 01:54 AM
2ponchos's Avatar
and how do i measure pinion angle?? thanks
also should i just leave them alone?? since they did come from spohn factory preset and i am using the brackets i will definetly hook better?? i already hooked good coming off the line why i dont know the car always hooked but i thought since i was putting in my new motor why not try them!! hope to see some improvment
Old Apr 8, 2002 | 06:33 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i think you need and adj. torque arm to adjust pinion angle. the lca's won't do that i don't believe.
Old Apr 8, 2002 | 07:43 PM
Z28DJP1987's Avatar
You should have got the standard non-adjustable LCA & Pandhard bar and saved some money on the brackets. If you don't know how to adjust them, you will screw up your pinion angle and who knows what else. My opinion.
Old Apr 8, 2002 | 09:08 PM
2ponchos's Avatar
well that is why i am asking how to do it how else can some one learn?? thanks for your opinion though
Old Apr 9, 2002 | 11:47 PM
th easiet wy to set the pinion angle is to park on a slab of cement that seems to be as close to level as possible and flat. Next, get an angle finder, set it to zero on the ground and them stick it on the bottom of thr axle housing benieth the pinion on the flat. This should give you a close number.
Old Apr 9, 2002 | 11:51 PM
Oh yea, hte control arms have just as much to do with pinion angle as the torque arm. The only time the torque arm only has control of the pinion angle (by it's self) is if the lca's are not adustable.
Old Apr 10, 2002 | 02:23 AM
2ponchos's Avatar
so lets say they are set at stock now and they are supposed to be stronger then stock will i see a difference without touching them till i can get an angle finder? where do i get a angle finder?? and what would be an optimal number to shoot for?? also the LCA'S are in the bottom hole on the brackets right now.. so what would happen if i shortened them and put them in the top whole jsut trying to figure out what the different holes do and exactly hwo to set these for optimal hook up wish spohn would have sent an angle finder or put in his instructions specifc ways to adjust these for what a person wants in his or her application other then that i am wa happy with the way they look and the structure of them thanks for all your help guys.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
