Wire separators w/ MSD Super's and LO3
Old Apr 19, 2002 | 08:15 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
For all of you who have put MSD Superconductors on your basically stock L03's, what have you done about wire separators? The stock ones definately aren't big enough. The ones that they sell at the generic parts stores aren't quite big enough for the 8.5 mm's either. The drivers side seem to be resting on the steering shaft as of now. Are there any larger replacement ones that go where the stockers used to go? Any pictures or info would be very helpful, as would part numbers and approximate prices.
Old Apr 20, 2002 | 05:47 AM
deadtrend1's Avatar
Zip Ties....
~Tim
Old Apr 20, 2002 | 08:06 AM
FAST85Z28's Avatar
ha... That what I used
Old Apr 20, 2002 | 09:46 AM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
i used them too... i got a set of polished aluminum wire separators for centerbolts from summit but they dont clear the edelbrock tes headers air tubes... 50 bucks and i cant use them....btw if anyone wants them let me know.,
Old Apr 20, 2002 | 11:42 AM
racereddy20's Avatar
haha I thought I was the only one that had zip ties on my msd wires. Cool I dont feel like I'm alone anymore. I had problems with my old wires laying down on the headers and I replaced them yesterday with msd wires. Since I had just spent double of what I normally spent on stock wires, I didnt want my msd wires laying down on the headers. So I zip tied them away from the headers.
Old Apr 20, 2002 | 09:55 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
zip ties are to mechanics what caulk is to carpenters
Old Apr 21, 2002 | 07:01 AM
DM91RS's Avatar
Car: 91 RS
Still not complete...wires too close to headers. This is a modified Moroso centerbolt kit.
Old Apr 21, 2002 | 06:41 PM
poncho9789's Avatar
Go to your local parts store and get the normal wire seperators that you would have used with the 8mm wires then take a dril and drill them out to 8.5mm it is a little odd doing this but it works.
Old Apr 21, 2002 | 06:43 PM
poncho9789's Avatar
or get the ones from summit that bolt to the centerbolt valve covers and go on top of the cover and not the ones that drop off the side and you can drill them out
Old Apr 21, 2002 | 07:07 PM
rscamaroman's Avatar
Used the zip ties on mine too. Not professional, but hey it works and its cheap. I like the looks of that engine compartment, DM91RS. Where did you get those valve covers?
Old Apr 22, 2002 | 04:01 PM
DM91RS's Avatar
Car: 91 RS
Thanks.....
The covers came from Summit and are made by TD Performance.
Old Apr 22, 2002 | 06:16 PM
Faithbird88's Avatar
i have the same wires, Jegs has then for about $20, there made specially for MSD 8.5 super conductor wires, there a clean, stream line style and has MSD printed on them, if you need anymore info e-mail me at londonaftermid21@aol.com
Old Apr 24, 2002 | 05:16 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the 8.5 MSD wires with the Made-For-You Products wire looms for center-bolt valve covers.
They're expensive but look better than any others and hold up well in the hot engine compartment.
Part#5035611 (black), $41.69 from Summit.
Summit#MFY-5035611, also available in a bunch of other colors.
-Rich-
Old Apr 24, 2002 | 09:07 PM
Engine: 5.7L
i got those 42 dollar ones rich is talkin about...if anyone wants them let me know.... they do not clear the air tuves on tes headers as i soon found out
Fanatic1074
Oct 3, 2022 05:57 AM
tyeo098
Nov 30, 2015 06:27 PM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
RedLeader289
Sep 23, 2015 06:50 AM
