Cleaning up engine bay
Old Apr 21, 2002 | 04:51 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Ok... I spent the weekend cleaning up the engien bay. I have almost go the pass. side valve cover cleared. I removed smog valve, and re-routed the heater valve to the pass. side fender. I do have a queestion about the pipe that runs behind the engine which fed air to the exhaust manifolds. Is there any way to get that out of there, or am I pretty much stuck with that until the engine is pulled or something? I know I have to get under the car and take out the bell housing bolts to remove it I think. If it comes to that, I think I'm going to leave it in there until I possibly drop the tranny again, or else take out the engine.
Old Apr 21, 2002 | 07:18 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
that pipe ur trying to get out... i think ur talking about the air injection to the catylytic converter. to get it out u have to get a bolt on the back of that cylinder head out. theres a ground wire connected to it which u gotta take out also. just make sure u reconnect it. on the cat, the pipe should be welded on so ur gonna have to cut that off. if u need to take emissions soon, make sure u can connect everything back the way it was. i dunno what u can use to plug up the hole on the cat then but plug it somehow. gopt any questions email me
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
