Its a 327! Tas, your good...
Old May 3, 2002 | 04:42 PM
deadtrend1's Avatar
now i just gotta figure out what heads were on it. It has a comp 270H cam in it, and the strock measured out to a 327. Is that still worth 200 beans?? Most of the engine is in good shape. The crank is fine, cam is good, pushrods and springs are good too.
~Tim
Old May 3, 2002 | 04:48 PM
iroc22's Avatar
$200 for just about any 327 now sounds like a awesome deal.
What year is it exactly?
Old May 3, 2002 | 05:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Old May 3, 2002 | 05:37 PM
Tas's Avatar
Tas
Old May 3, 2002 | 08:20 PM
deadtrend1's Avatar
well, uuhh .. the year is a mystery also. HERES THE STORY:
This guy at my work is selling his 70 monte carlo, and from the start, its a project car. So much of a project car it would even put first union to debt rebuilding it. He said the engine has 2,000 miles max on it but sat for the longest time and swore it was a 350 with a holley high rise manifold and a 750 cfm carb. It ran like **** and we believed the carb was to blame. The guy was a idiot and knew NOTHING about it, and so my friend bought it. We tore the engine apart the other night for the heck of it because hes junking the car, its rusted so bad its not even funny.
I believe the head gasket blew cause water was everywhere. Now im trying to find out what the heads are on it. If they are 350 heads then that would make it somewhere near 340ish??
So, its a nice fun project to keep me off the streets and learn a lot from. Got it pulled and its on a stand now just screaming for help. And i want TBI and not carb for some reason ..
~Tim
Old May 3, 2002 | 10:13 PM
steve8586iroc's Avatar
What are you implying here? You've got me scratching my head on this one.
Steve
Old May 3, 2002 | 10:38 PM
iroc22's Avatar
I'm gonna step out on a limb and address this one...
OK it's the bore and stroke that makes the cubic inches on an engine. The heads have nothing to do with it. It's the volumetric capability of the block and crank, not the external parts.
Old May 3, 2002 | 10:39 PM
iroc22's Avatar
Oh and take the valve covers off and get the casting #. It will be between the valve springs and be about a 8 digit or so #.
Old May 3, 2002 | 11:43 PM
deadtrend1's Avatar
ok .. i checked the casting number and it looks like 3998991. Maybe 3988991 but the 3rd digit looks more like a 9.
Old May 3, 2002 | 11:45 PM
iroc22's Avatar
Ok take the # over to www.mortec.com and match it up.
Old May 4, 2002 | 12:02 AM
deadtrend1's Avatar
i didnt find it there .. but i searched google and got this...
Years Casting# CID Intake Exhaust
1968-69 3998991 307 1.72 1.5
1970-76 3998991 350 1.72 1.5
oh wait .. here it is on mortec...
3998991....72-73...307/350......75cc chambers
Old May 4, 2002 | 10:28 AM
Dan94GT's Avatar
maybe it is a 307. they have the same 3.25 stroke as a 327 but a slightly smaller than 4.00 bore. something in the 3.8 area I believe. 307s are considered just as undesirable as a 305 but I think they could be built up a little better than a 305 since the bigger bore (its still not big enough). The tape measure/ ruler isnt accuate enough, you need to mic it out. Or run the #s on the block. if the heads really only have 1.72 intake valves then they suck ***, regular 305s have 1.84s right?
If its a 307 and you still want/need the motor to mess with offer a little less $100-$150. If it is a 327 buy it, you could make it a 350, or 383 if you want. but a 327 may be the way to go.
get better heads whatever it is if that is the right info.
Old May 4, 2002 | 01:05 PM
iroc22's Avatar
The 307 is a 283 block (3.875") and the large journal 327 crank (3.25"). Idealistically the 307 is a more performance-orientated bore stroke combination than the 305. But still undesirable.
The "416" and our "187" 305 heads have 1.84 intakes. All others have 1.71" intake valves.
Those heads *cough cough* suck
Old May 5, 2002 | 12:06 AM
deadtrend1's Avatar
AHHHH, Well .. a expert came over and measured it out. BTW, i didn't measure ... im relying on what my friend's dad is telling me cause i haven't had the chance to check it all.
ITS A 350 .. it is a 4" bore with a 3 1/2" stroke. Checked in the books and it says its a ginuine 350. i was right the first time.
The reason it wasn't running correctly was my first guess also ... BLOWN HEAD GASKET. So, with the money I saved on all the other crap for it .... i can buy some nice aluminum heads .. WEEEEEEEE :lala:
I got till the end of summer to get this engine built cause im getting a new car.
~Tim
84 TA NV
Sep 6, 2015 08:02 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hayesaw0210
Aug 23, 2015 11:15 PM
Metallica383
Feb 23, 2001 04:31 PM
JC88Camaro
Sep 22, 2000 12:55 AM
