Question w/ IAT, open element filter & poor throttle response
Old May 7, 2002 | 09:16 PM
MILT's Avatar
As the subject says; my problem lies with an SES light (constantly lit) and poor throttle response. The worst problem is a severe bog that sometimes kills the engine when revving or @ WOT.
This arose following open element install. I tried wiring in a 7.5Kohm resistor, I tried leaving the IAT open, but nothing has seemed to work thus far.
Any opinions?
MILT
Old May 7, 2002 | 10:57 PM
'89 IROC Vert's Avatar
Thanks, MILT.
I just had my headers back put on, then put on a 14x3 open element. All ran great until last Sunday - WOT and it just bogged down. I removed the air cleaner and drove home (3 mins away, Thank ***) without it. Once I removed it though, the car kicked right on over and off I went.
What the hell happened? I'm at a loss.
Old Mar 22, 2011 | 11:42 AM
crazymonkey16's Avatar
Car: 1990 Camaro RS
Engine: L05 TBI
Re: Question w/ IAT, open element filter & poor throttle response
Check to make sure your open air element isn't grounding something - I spent 3 weeks and about 15 fuses on a wild goose chase before a friend just took it off and it ran fine. Mine was grounding against one of the injector wires.
Old Mar 22, 2011 | 02:57 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Date of the last reply in this post: 05-08-2002, 04:57 AM
I think/guess/hope the OP figured out he was grounding something by now.
Old Mar 22, 2011 | 08:32 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
lol possibly...or he sold the car..
Old Mar 22, 2011 | 09:18 PM
Car: 1990 Camaro RS
Engine: L05 TBI
HOLY CRAP... lol, I totally skipped over the year in the date... lol, i'm a retard. :P
Old Mar 22, 2011 | 09:29 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I have done it before too...Im just curious..you were searching for this topic?
Old Mar 22, 2011 | 09:38 PM
Car: 1990 Camaro RS
Engine: L05 TBI
Well, I was searching for anything related to the IAT/MAT... I've been putting my 90 RS back together slowly over the past year... it's my DD, and the guy who had it before me just started plugging hoses and deleting systems rather than fixing them. It *did* run, just not near as well as it should have... so I've been slowly re-introducing systems back into the whole system, and since I'm no mechanic, it's been quite an experience. I've gotten it down to one SES code left, 23, which deals with the IAT/MAT... I found the wires that plug into it, but the sensor itself wasn't with the car when I bought it, I don't believe... so I'm trying to figure out what it looks like. I work at a NAPA store, and when I looked it up in our computer, it showed three options... one of them is a rectangular assembly, which i've seen before, but won't work with the plug in my car, one of them listed is actually the coolant temp sensor, and the third looks similar to the coolant temp sensor, except it has a cage on the end with a little filament of sorts inside it... I'm assuming the third is what I need, but I was trying to find pictures. Unsuccessfully. :P
Old Mar 22, 2011 | 09:59 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
that's what the stock one in my car looks like. not a great picture i know. But its a 2 wire sensor. and it does have a filiment on it basically.
Old Mar 22, 2011 | 10:01 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
this is when I had it mounted in the powercharger you can see the filiment this is a different sensor. I have a Niehoff part # of FE625 you should be able to interchange that to napa brand if it is what you needed
oh and btw I have a stock one pictured and an aftermarket one of that part # if they seem to be what you need and you cant find one ill sell you one cheap.
Old Mar 22, 2011 | 10:16 PM
Car: 1990 Camaro RS
Engine: L05 TBI
I found one at NAPA... had to order it, but it should be in tomorrow. Thanks though - it does look (somewhat) similar to the pictures here. Guess I'll throw it in and see if the code still sets off after the engine warms up.
Old Mar 26, 2011 | 10:34 PM
Car: 1990 Camaro RS
Engine: L05 TBI
Just as an update for you, UnderCover, i put in the IAT, and it could be my imagination, but my car felt like it drove so much better and actually had a little more juice afterwards... best of all, no check engine light (after a 120 mile drive north!)
Old Mar 27, 2011 | 10:04 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Sweet man. Sounds good so far
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Pac J
May 17, 2020 10:44 AM
amargari
Nov 10, 2015 02:09 PM
meeklay812
Oct 1, 2015 03:46 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
