On cold start, my RS could take on a Viper - what's up?
Old May 15, 2002 | 11:58 AM
bigman's Avatar
When I start my car up after it's been sitting long enough to be completly cool, it feels like a racehorse that has to be held in check. Two or three minutes of warmup and it'a a nice little 305 smog motor with barely enough power to get out of it's own way. It isn't that the RPMs are high, they're sitting around 750-1000 and it still has more power than normal at 1000 rpm. Now, I'm thinking that the fuel flow is higher and the timing is probably different, because on a carbed vehicle, you'd run the choke for a while which either chokes off the air flow or enriches the fuel flow. In either case, it sends a very rich mixture until the engine warms up. Anyway, any insight is appretiated.
Dan
Old May 15, 2002 | 12:07 PM
Nasty_Bird_'90's Avatar
mine does the same thing. played with the timing but nothing worked. what gives??
Old May 15, 2002 | 02:51 PM
wh0di's Avatar
A couple of things can cause that. I'd invest in a lifter valley oil deflector or an Air-Gap manifold to keep the intake mixture cool.
Next get a 180 degree thermostat and make a fan switch.
That is all i can think of at the moment
Old May 15, 2002 | 03:21 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
It is becasue your O2 sensor is not warmed up yet, and the veh is running richer. Once it warms up it starts reading the fuel mixture in the exhaust and will go from rich to lean and back and forth as it see's fit.
Old May 15, 2002 | 04:49 PM
NJ SPEEDER's Avatar
ti is also partially the illusion of fast idle. with the car pulling against the brakes and all teh extra fule around it feels like it takes off better, but at that point it is actually slower than once it is warmed up.
later
tim
Old May 15, 2002 | 08:31 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
anyone have any thoughts about whether cold motors run slightly higher compression or not?
Old May 15, 2002 | 09:26 PM
NJ SPEEDER's Avatar
a leak down on a cold engien woudl be worse than on a warm engine. once the engine has soem temperature in it teh metal will expand slightly and seal better.
later
tim
Old May 15, 2002 | 11:13 PM
Jza's Avatar
Jza
High revs before the car warms up isn't good for the motor either. Just a thought.
Old May 16, 2002 | 12:08 PM
HrdRockA4305's Avatar
I've heard its also because the tranny fuild is very cold, so it thickens up a bit, and this tightens up your convertor. Mine feels "strong" off the line when its cold too, but theres no way its actually making more power. Plus I don't wanna rev a cold motor very hard, I've heard thats not a good thing to do. Like this BMW... it had LEDs in the tach, and the redline gets higher as the motor warms up... how trick is that :hail:
Old May 17, 2002 | 05:13 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
bmw are sweet machines , gonna get one for my old lady i think
Old May 17, 2002 | 06:27 PM
Jza's Avatar
Jza
Or that new Lexus with the rotating tach that raises the redline as it warms up.. :hail:
Old May 18, 2002 | 09:21 AM
Nitroburn's Avatar
Mine does the same. The thottle response is unreal!!! So let's look at each of the comments and theories and put it all together.
1: We all know the during a cold start, it's not so much that the O2 sensor is cold, but the readings are totally ignored when the ECM is in open-loop mode. Thus, the rich mixture. With this is mind, it seems that our motors love the rich mixture (again, a proven fact about the TBI's) but it likes it on the lower side of the RPM scale as well. What to do? Richen the mixture up a bit (with more fuel press, I believe).
2: Engine temp: This one is probably gonna be beaten back and forth, but my guess is that the cool temps allow more timing throughout the RPM range due to lower combustion temps (less chance of engine knock). Install a lower thermostat.
3. Tranny fuild: I must admit, I never thought of that one, but it makes plenty of sense since the fluid it thicker when cold, the torque convertor is able to apply more torque to the input shaft on the trany, thus more torque to the rear wheels. Of course, this is only true on cars with auto tranys! Install a trans-cooler!
4: Fast idle: Sure, this engine is making more power as the RPM's raise, and since at idle the RPMs are upto 1000 more than warm idle, there's more power just waiting to be released instantly. How to fix this one? Raise the idle, right? Wrong. Install a higher stall converter. But make sure it's matched to the rest of your bolt-on parts (intake, cam, heads, etc...).
5: Temp of air coming into the engine. During a cold start, the temp of the air coming into the engine is the same temp of the air outside of the car. As the engine warms up, the air under the hood raises and so does the air coming in. Try to install a cold-air intake setup and/or a air-gap manifold.
These are just my ideas on these as I've spent a lot of time trying to figure it all out.
Old May 20, 2002 | 04:10 PM
iroc22's Avatar
Uh yeah...the oil cannot properly coat the bearings when it's cold because of it's thickness. So basically it's almost metal on metal. Why do you think turbo cars aren't allowed boost til warm? Cause the oil cokes the turbine because it's too thick.
I think one of the biggest influences in the power making ability of the engine, is the cooler denser intake charge. And when the engine isn't warm, the heat isnt being transferred to the incoming air/fuel because there is no heat! Thus the combustion is a much more efficient one.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
