Attn JVprepost.... Headers and Spark Plugs
Old May 16, 2002 | 09:16 PM
ImportsRsloths's Avatar
Attn JPrevost.... Headers and Spark Plugs
What are you guys running with your headers........ Im specifically asking JP because he is the only other person i know with SLP Tri - Y headers and im having problems with plugs.....
Old May 16, 2002 | 10:38 PM
JPrevost's Avatar
Car: 91 Red Sled
Off-set boxed end wrench works for the really hard to get to plugs (passengers side) and I use a standard plug socket on the drivers side with a standard wrench. There are a lot of different way to get to the plugs so try them all and definatly get a boxed end wrench for the tuff passenger side plugs.
Old May 17, 2002 | 06:18 AM
Well i can get to all the plugs fine and screw them in thats not the problem! The problem is is that when i go to the store and buy spark plugs for a 88 350 iroc and try to put them in, they are WAY TO LONG on most of the cylinders and i cant even get them started in the hole......... I need to know what plugs you are using??? U didnt have to loosen the headers up to install plugs?
Old May 17, 2002 | 09:33 AM
JPrevost's Avatar
Car: 91 Red Sled
Nope, I'm using standard plugs all around but it might be easier since I've got vortec heads. My plugs aren't in the standard position, they're moved closer to the exhaust valve and in some cases this makes starting the plug a lot easier.
Call up SLP and ask their teck guys, they have a prat number for shorter style plugs.
Old May 17, 2002 | 08:02 PM
Snowdog 91 Formula's Avatar
Yeah you can get them from performance shops too. Expect to pay a little more for them....
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
