How can I find out for sure if my car has a roller cam?
Old May 25, 2002 | 08:34 PM
TBI305Camaro's Avatar
Ok I know 88 was supposedly the first year for the roller cam but how can I find out for sure my car is?
Old May 25, 2002 | 09:43 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
open her up
Old May 25, 2002 | 10:27 PM
evil t/a's Avatar
If thats the original engine then you have a roller cam.
Old May 26, 2002 | 12:24 AM
JPrevost's Avatar
Car: 91 Red Sled
And if it isn't original, pull the intake manifold and look at the lifters. If you have access to a cool small camera then remove the dissy and look through the whole for the lifter "spider" .
Old May 26, 2002 | 01:01 AM
its the original motor for sure...ive had the intake off didnt really know what the hell i was looking for but....i was just wondering because i could get a hydraulic cam for so much cheaper than a roller
Old May 26, 2002 | 01:14 AM
evil t/a's Avatar
If it is original then you have a roller cam. If you arent convinced then DO NOT pull the intake . Jusy pill one valve cover and lossen one roker are and remover the pushod. Measure it or compare it to a flat tappet SBC pushrod , the ones for roller cmas are short than the one for flat tappets.
Old May 26, 2002 | 12:06 PM
JPrevost's Avatar
Car: 91 Red Sled
That's a better idea so long as you've got a standard hydralic pushrod on hand, even if you didn't, just measure it.
If you are going mild enough, a standard cam is fine for performance. It's when you want to squeeze every last bit out of the motor that a roller cam comes into play. I'd love to have a roller cam but my motor didn't come with one and it's working fine without it. Like you said, roller cams are expensive and where I'm at I wouldn't really benifit enough to justify dumping at least $300 into a roller cam swap.
Old May 26, 2002 | 03:42 PM
iroc22's Avatar
Re: How can I find out for sure if my car has a roller cam?
87 was the first year.
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
