chips?!?!?! I'm going NUTS!!!
Old May 28, 2002 | 04:47 PM
fakezcar's Avatar
I've heard some crazy stuff lately....Take the chip out of a '90 Caprice wagon.....It makes the computer think the car weighs a millionpounds and has the ***** t run a .040 over 350 w/ a mild cam!!!Am I NUTS or is this ???? What do you guys think? I'm on a major budget!!!(just broke my figgin' radiator!!!!) Hopefully this is true.......five finger discount from the local boneyard.....what about injectors? I've been told the 305 one will work fine....PLASE I'M GOING NUTS!!!
Old May 28, 2002 | 04:53 PM
wh0di's Avatar
Dont worrt about chips just yet.
Put a gear swap under your belt, and some engine modifications before you tackle a chip.
Im not too sure, but you cant really see any gain over the stock chip while the engine is still mostly stock.
Old May 28, 2002 | 08:23 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
a couple things - one - from what i've heard, a chip will make a huge difference if done correctly (read: not from Hypertech or some generic company - but diy or by a trusted friend). Two - .040 is a lot to punch a 350 out for performance...why not just go .030 over? Just wonderin' - i've seen them go .060 over, but that's craaaaaaaaazyness.
Ty
Old May 28, 2002 | 08:57 PM
Tas's Avatar
Tas
.060" over is not craziness. It's better to go .030" in the first place so you can do .060" in a couple years.
Old May 29, 2002 | 05:47 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
alrite - i just have never seen any big performance motors built at the shop i go to that are more than .030 over - you get thin walls don't u?
Ty
Old May 29, 2002 | 10:34 PM
fakezcar's Avatar
.040 over isn't large..as was stated it only cuts down on the chance of going .060 over later on...that's okhough cause this motor is just to get me until i can afford the full out resto-mod.....cage,t-56,lingigfelter 427 TT LS-1, 9-inch, etc. Any way i just want the chip to handle the motor and not blow it up before i can afford the chip custom burned. The kick of it is can the caprice chip run my mild small block???It better cause the motor is just waiting for the front suspension to be fixed and then it gets dropped in....read next week....any wayi's someting to pick at your brains.
chris
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
