Problem after cam swap
Old Jun 7, 2002 | 06:54 PM
psycho305's Avatar
I have another problem after my cam swap, the engine is backfiring nearly each time I step on it. Never from dead stop but each time I am driving and I push the throttle, I can hear a big bang and the engine stops for half a second.
I had trouble with my ignition so I brought it to a "reputable" mechanic to have it set properly but it still backfire.
What is wrong?
I didn't bump the fuel pressure or change anything from the ignition and TBI
Is it because of a lean condition?
I have a small oil leak from the rear of the manifold.
I have headers, and the cam was an LT1.
The car doesn't run good neither, it makes real power at nearly 4000 rpm.
Sorry for the lenght but I really don't know what to do.
Thanks for your answers,
Jacques.
Old Jun 7, 2002 | 09:56 PM
RacerXWS6's Avatar
Check your plug wires. Could have a few crossed. I had to straighten out a friends TA today because he did this same thing. Car wouldnt run well, and would pop and backfire. He had the #8, #6, #4, and another plug wire Ive forgotten crossed up.
Old Jun 29, 2002 | 01:51 AM
Keith5's Avatar
Car: C1500
Did you ever get it straighted out? Mine ran fine for the first 100 miles today, but then coming home I stepped on it and it backfired.
It doesn't have real good power, but as good as a expected from stock fuel delivery. I plan on bumping the fuel pressure in the next week or so.
Old Jun 30, 2002 | 04:48 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Keith5,
Just curious on how the LT1 cam compares to the stock cam powerwise.
As far as fixing problems, some of the things I've read on this board include: bumping the FP, advancing the timing to about 8*, and checking that the timing chain is installed correctly. Of course, burning a prom is all important as well.
Old Jul 1, 2002 | 08:55 AM
psycho305's Avatar
I did find the problem, it was the bolt that hold the distributor in place that was not tight enough.
Each time I would adjust the timing, while driving, it would slightly turn and retard the timing to a point where it was making the car backfiring.
Now it runs fine, after many tries, my timing is set at 14° btdc.
There is definitly an increase in power in higher rpm.
Old Jul 1, 2002 | 09:47 PM
Keith5's Avatar
Car: C1500
I have adjust some more on mine, it's at 6* BTDC now, it seems to be running good there for now. I need to bump the fuel pressure now. I've noticed my entire power band has moved up about 2000 rpms, there will be a lot more power there when I get the extra fuel in there, right now it may have like 20 extra horses, it's starving for fuel bad.
I didn't just do the cam though, I did heads, headers, intake and cam.
1984HO
Mar 19, 2021 11:59 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
anesthes
Mar 10, 2016 10:35 PM
gta90
Sep 15, 2015 04:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
