Biggest TBI spacer
Old Jun 26, 2002 | 10:24 AM
BowtieFever's Avatar
Biggest TBI spacer
What is the biggest tbi spacer I can put under my tbi? I want everything to clear and hook up as it does stock? Any recommended materials? I have a 2.5" cowl hood, so I have the clearance. Will I notice any performance increase? Thanks in advance.
Old Jun 26, 2002 | 11:02 AM
My305camaro's Avatar
How big of a spacer depends alot on your own personal setup. A flat base open element filter almost touches a stock hood, so I would say if your cowl induction is 2.5 inches it would make sense you could run up to a 2.5 inch spacer. The only problem you would run into is: Will the fuel lines reach/clear the TB? And will the throttle/tranny cables reach or will you have to do some fabrication to get it to install correctly?
I think I heard somewhere that you get better throttle response but not alot as far as e.t.'s go...
Hope this helps!
S10K20
Oct 7, 2015 06:45 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Glowsock
Sep 11, 2015 11:09 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
