What to MOD next?
Old Jun 28, 2002 | 04:06 AM
RS91's Avatar
What to MOD next?
I've done a few modification and wondering what to modify next?
pls. look at my sig. and let me know your suggestions..
Thanks...
Old Jun 28, 2002 | 10:14 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
How much do you want to tear into the sonofabitch?
Id say posi and gears (3.42s or 3.73s) would be a great route. An LT1 cam would also help you tons, but thats a big job.
Old Jun 28, 2002 | 10:25 AM
3five0's Avatar
For sure the rear is where you are going to find the most improvement on your car. If you have an auto you need some 3.42's. If it's a stick then 3.73's are looking good for you. If it is an auto you should really think about getting a shift kit. When I had my mini-mouse L03 305 I could spin the tires during the first-to- second shift. Wait on a chip if you are going to mod your engine more. If your not you should look at a stage 2 chip from Jet or Hypertech or Superchip or Granny's Jewelry box.
Old Jun 28, 2002 | 12:14 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Definitely recommend the $99 Zexel OEM Posi and 3.42 gears. Much improved my car. It's a great bang for the buck. Then I would go with the LT1 cam.
Old Jun 28, 2002 | 12:24 PM
iroc22's Avatar
I would definitely take the camshaft route first....gets more air/fuel into the cylinders over the peanut cam.
Old Jun 28, 2002 | 05:56 PM
RS91's Avatar
Thanks for all the info. Just to let you know that I use this car as my daily driver. If I go with the Posi and gear, how hard is it to install? And How much do you thingk it will cost me? I don't know anything about Posi and Gears.
Your help will be greatly appreciated!
Old Jun 29, 2002 | 10:20 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
cost me 90 bux for somebody to install it. that is with me taking the rear end out of the car and giving him everything he needed to install it. 100 dollars for the posi, 180 for the richmond gears, and 130 for the mega install kit
Old Jun 30, 2002 | 09:17 AM
Coop89RS's Avatar
Hey brharris where can I get this oem posi from?
Old Jun 30, 2002 | 01:13 PM
www.slponline.com
Old Jul 1, 2002 | 02:25 PM
Mr300's Avatar
has anyone put in the 3.42/3.73 gears or the LT1 cam? if so what are your improvements in the 1/4 mile.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
