need 350 ingectors
Old Jun 29, 2002 | 10:29 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
need 350 ingectors
like it says... My new engine is running crazzzy lean. Is there a good place to get new/used 350 injectors for a reasonable price? The local autozone carries some noname units but i dont know if i trust them.
Old Jun 29, 2002 | 05:45 PM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
What lbs. you got now? What lbs. you want? 350 injectors out of trucks are 55#, cop car 350's are 65#, 305 camaro is 45#, any and all will work but what you got now that are too lean? What set up you got, mine is runnin 65# cop car injectors and im running great. I got a pair of 45#ers that work fine but I doubt those will help you.
Old Jun 29, 2002 | 06:03 PM
Car: 88 Camaro SC
Engine: SFI'd 350
ive got the 45 # that came wiht my 305 with the fpr turned all the way up. If im running lean with the 45 # then the 55# probably wont help enough. Maybe my fp is on its way out and the injectors arnt getting enough pressure. THe engine runs lean (o2 of 0-.15 volts) even when the engine is under no load and the blms are high. Id expect it to run a little lean but that seems kinda crazy. The engione itself is the stock 210 HP pre 86 one wiht 8.5:1 CR. Id like to resolve this so i can break this engine in and be on my way.
Old Jun 30, 2002 | 10:23 AM
rsc350's Avatar
Car: 92 Camaro RS
All I can say is that the 45# are definatly not enough for that engine, 55# would sound right if the internals are stock, you sure your timeing is right, retarded timeing makes it lean out, maybe put in a fuel pressure gage in line and see what the psi on that is.
Old Jun 30, 2002 | 11:05 AM
Car: 88 Camaro SC
Engine: SFI'd 350
im going to try all that probably on wed. I have an engineering calc (AKA calc 5) exam coming up so that gets priority over the car.
Old Jun 30, 2002 | 09:31 PM
Car: 88 Camaro SC
Engine: SFI'd 350
i decided to go out and i picked up a set of 350 injectors and its fine now.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
