New shift points?
Old Jul 4, 2002 | 01:00 PM
RallySport92RS's Avatar
New shift points?
I get the car back tonight with the LT1 cam installed!!
I heard that the LT1 cam can make it possible to shift higher when racing. Right now my car shifts at 4500 rpm when I floor it (its an auto). Would it be better to shift above that now because the cam can handle it, or will this hurt my engine?
I also read I will lose some low end power but will make it up past 5000 rpm so should I shift above 4500 rpm?
Old Jul 4, 2002 | 02:59 PM
iroc22's Avatar
Yes I guess so. You need to really play with the car when you get it back. Rev it up and shift it, shift early; see what works the best with the new cam. I'm hoping you got the springs changed with the cam.
Old Jul 4, 2002 | 03:44 PM
Yeah I got new springs, push rods, seals, gaskets, and timing chain with the cam.
It is safe to rev it up past 4500 rpm though?? there isn't a chance I can blow the engine doing that is there?
Old Jul 4, 2002 | 03:46 PM
iroc22's Avatar
Oh no. You would able to rev to 6000rpm with all those new parts, if your heads will flow enough air/fuel to make it there. You still have the stock heads?
Old Jul 4, 2002 | 04:44 PM
Yep everything is stock on my 92RS except for gears and full 3inch exhaust, still possible to goto 6000rpm?
Old Jul 4, 2002 | 04:58 PM
iroc22's Avatar
Maybe, I don't think that the heads could support enough airflow at 6000rpm though to pull up to it.
Old Jul 4, 2002 | 05:11 PM
Well I know what my next mod is going to be then! lol
Old Jul 4, 2002 | 05:19 PM
iroc22's Avatar
Yeah heads will really wake up the L03.
If you're willing to spend the money, Vortecs are the best way to go. They're cheap to buy, but to make them work you need to mill them and get a Vortec specific pattern to fit the heads.
Next choice would be the World S/R 305 Torquers. Excellent heads and will benefit hugely from mild porting and polishing. Very reasonably priced too.
If you're really on a budget you could pick up '416' castings from LG4/L69/LB9 and port them a lot. And I mean a lot.
Old Jul 4, 2002 | 11:30 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
when you race shift manually, I do at 5,000 so you should be able to due about 5,500 or slightly less
Old Jul 5, 2002 | 01:37 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Just a suggestion-invest $40 for a MSD coil. Stock coils generally start to lose their voltage output between 4,500-5,000 rpm. I still have the stock cam and use the MSD coil and shift at 5,500rpm when racing. I have an auto as well, and shifting into 2nd at 5,500 really helps because it keeps you in a better part of the power band. It should deffinetely help with that LT1 cam in there. Let us know on how it turns out!!!
Old Jul 5, 2002 | 12:40 PM
iroc22's Avatar
Yeah true when I swapped in my MSD Blaster over the stock coil, it made the car rev that little bit further on the top end.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Out-Cast
Sep 11, 2015 08:03 AM
