engine swap
Old Jul 18, 2002 | 04:08 PM
ssnow2020's Avatar
engine swap
What kind of problems would i run in to if i used a 96, 350 vortec motor with alum. heads out of a yukon it is only 100 dolors and runs fine ????in my 91 firebird????other then needing a manifold and some way of hooking up egr provision?
Old Jul 18, 2002 | 05:40 PM
Tas's Avatar
Tas
it doesnt have aluminum heads. You can use the Vortec tbi intake if you want EGR.
http://www.sallee-chevrolet.com/Chev...ortec_TBI.html
or you can run a vortec intake for a carburator and use and adpater plate but I don't think any of those have EGR.
Old Jul 18, 2002 | 11:14 PM
ssnow2020's Avatar
im pretty sure they are alum. they looked like it and i could have sworn the ozidered a bit like alum. does
Old Jul 21, 2002 | 01:13 AM
ssnow2020's Avatar
is it true i will have problems with the water pump???
Old Jul 21, 2002 | 11:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
hmmm... i thought those where cast iron. Anyhow. Youll have problems with the induction system. Youll need to burn a prom and get the 65# injectors and intake to get it to work right. Probably not a bad idea to get a 670 cfm holly tbi too. Youll need to plumb a line off your headers/stock exaust crap-ifold to feed the egr if oyu want to use it. Otherwise, its like any other 350
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
