surging throttle/bad response
Old Aug 16, 2002 | 01:57 AM
gettaway305's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Hello...I just finished putting headers, a high flow cat, and a 3 inch catback on my L03...I know this is way too big exhaust for this engine, but I plan on switching engines in the future...
Anyway, I realized that I would loose a lot of low end torque (and I did...i can barely peel out now), but Im having some problems in the 3000+ RPM range.... The car is surging, like itll pull hard for about 1/2 of a sec then it wont, then itll pull hard again, etc. Does anyone know what would cause this? It did not do it before, and its nothing like a clutch slipping.
Also, what are some ways to increase throttle response on the L03?
Old Aug 16, 2002 | 06:35 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
my surging problem was because of a burnt spark plug wire, which you could easly have now because of headers, could also be a spark plug
Old Aug 16, 2002 | 07:42 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Wow, that sounds like the problem I have been having. I believe that it is a lean fuel problem. You freed up your exhaust, and with the extra exhaust flow, you have more intake flow, which requires more fuel to maintain the desired air:fuel ratio. It could be your fuel pump, or you'll get lucky and cure the problem by boosting your fuel pressure ($0.25 mod).
Good luck
Old Aug 16, 2002 | 12:39 PM
Car: 1989 Camaro RS
Engine: 305 TBI
how do i boost the fuel pressure?
Old Aug 16, 2002 | 01:54 PM
Car: 1989 Camaro RS
Engine: 305 TBI
nvm....found the page...Im gonna go ahead and try those tbi mods
thanks for the help!
Old Aug 16, 2002 | 06:53 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Sounds like you might have not conected the O2 up right.
Old Aug 17, 2002 | 01:21 AM
Car: 1989 Camaro RS
Engine: 305 TBI
I dont see how i could have connected it wrong...its only one wire
Old Aug 17, 2002 | 11:34 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Could it be possible that the O2 got bashed a little, maybe cracking the internals.
92camaro350cci
Oct 14, 2015 09:29 AM
meeklay812
Oct 1, 2015 03:46 PM
BWilcox
Sep 20, 2015 12:19 PM
banksGTA
Sep 13, 2015 11:56 AM
rsrookie
Sep 5, 2015 07:08 PM
