What are some symptoms of a bad map sensor?`
Old Aug 17, 2002 | 10:45 AM
sslee's Avatar
The scan tool says I have 11-12" of vacum at idle and the gauge says 18". I am having hard start problems. It won't start unless I hold the gas pedal down just a bit , same hot or cold.
Old Aug 17, 2002 | 10:46 AM
sslee's Avatar
I have no vacum leaks either.
Old Aug 17, 2002 | 01:51 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if there is a difference between the gauge, assuming its correct, and the map output then odds are the map is bad.
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
