just got LT1 cam HELP
Old Aug 20, 2002 | 02:13 PM
rad8tion's Avatar
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
I just got an LT1 cam to go in the 355 (350 + .030) I am going to replace my 193k mile LO3 with.
My Problem
I went to bolt the timing gear on and it didn't fit, the dowl pin is not lineing up, the pin on the cam is further inward than the hole on the gear.
I have a non roler cam that this gear will bolt to.
Do I have the wrong cam or the wrong timing set?
Ryan
Old Aug 20, 2002 | 03:02 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
You must have a timing gear for a factory roller cam engine. The standard flat tappet cam has a larger bolt pattern. Go to the parts store and tell them you need a timing chain and gears for your L03 and you will be fine.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
masonta
Sep 1, 2015 06:40 PM
