oily mess
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
well my friend had the same problem and when he replaced the valve cover seals it helped a lot and they where only 12 bucks a piece i don't know about you but to me that price sounds about right
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
blue smoke on startup is the valve guide seals. If the engine smokes under load then its probably the rings.
