Stock HEI and an aftermarket multi spark unit
Old Sep 5, 2002 | 06:52 PM
CHEVYTOWN's Avatar
I was wondering if a stock HEI can handle an aftermaket multispark unit like an MSD or whatever? Or would that fry the stock module and coil?
any help greatly appreciated hometowns....Ctown
Old Sep 8, 2002 | 09:22 PM
JPrevost's Avatar
Car: 91 Red Sled
It's a bad investment. The stock HEI setup is a great system for up to 400hp while keeping less than 10:1 compression. If you've got more hp, more compression, and are running a cam/intake that's moved the powerband to a peak hp above 6000rpm then get a hotter (more voltage) coil. Then if you're running some anti-street cam, race gas, race everything THEN get a CNP (coil near plug) or COP (coil on plug) ignition system that's like the LS1's and similar truck motors. All it takes is some creative equipment and you've got a CNP setup for under $600, depends on where you get the actual coils and where you get a 96' truck vortec 350 distrib (has a cam position sensor). Then you need the EDist which will run the coils on your car , this is the best upgrade, don't waste money on the MSD stuff unless it's just a hotter coil upgrade.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
92camaroJoe
Aug 13, 2015 06:07 AM
ZsTransAm
Aug 11, 2015 07:30 PM
