TBI acting like a 4bbl????
Old Sep 8, 2002 | 07:21 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
please help!!!!!!!!!!
i have a 91 Camaro TBI 305 when you start it up to warm up it runs EXTREMLY RICH and eventually floods out
then if you hammer it after driving the service engine light comes on and it floods out
when it does this the throttle body whistles EXTREMLY loud
so far i have replaced the fuel pressure regulator
map sensor
coolant temp sensor (INTAKE)
fuel filter
could it be the injectors going bad?
Old Sep 8, 2002 | 08:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
what codes does it throw? What is your fuel pressure? Theres always the possibility that the one you where sold is set for an incorrect pressure. All that noise is probably all teh extra fuel squeezing throught he passages near the throttle blades.
JPrevost's Avatar
Car: 91 Red Sled
It is VERY unlikely that the injectors are going THAT bad to cause such a rich condition that the car sets off an SES light and floods. I would do the basic stuff like checking fuel pressure and pulling the error code(s) from the ecm. I doubt it's the o2 sensor and that whisling is usually the IAC motor going crazy because some sensor is fubar.
Reply to this when you've got an error code then we can help.
Old Sep 8, 2002 | 09:32 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
ok guys thnx i will hook a scanner to it tomorrow
Old Sep 9, 2002 | 07:06 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
ok a friend of mine did the wire thing with the diagnostics connector
code 23
code 15
Old Sep 9, 2002 | 07:21 PM
flotsamm's Avatar
Check out the FAQ here, and look at towards the bottom:
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Code 15- Low temperature indicated at engine coolant temp. sensor
Code 23- Low temperature at manifold air temperature sensor OR
Throttle position sensor error
Sounds like you may need a bew TPS since you already replaced the CTS. However, dont rule out that the CTS is okay.. could still be bad.
Old Sep 9, 2002 | 07:25 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
the coolant temp sensor is in the intake manifold and there is one in the right head right?
Old Sep 9, 2002 | 07:31 PM
flotsamm's Avatar
Here ya go, check this thread out.. theres a post about where the three sensors are. Also do a search in this forum for code 15.
https://www.thirdgen.org/techbb2/sho...hlight=code+15
Old Sep 9, 2002 | 07:36 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
looks like im gonna be replacing the one next to the thermostat
Old Sep 9, 2002 | 08:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
intank=comp
head=gauge
Old Sep 10, 2002 | 07:21 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
thanks a lot guys it was the coolant temp sensor in the intake manifold i can't beleive that tiny part did all that to that car well now i gonna replace all 8 plugs they are pich black
but at least the car is back to destroying Hondas
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
ironbmt
Sep 27, 2015 06:00 AM
