Throwing Codes ...
Old Sep 13, 2002 | 04:09 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
Throwing Codes ...
I don't know if my car has the Pre-Race Jitters or what, but he's throwing two different codes.
1. Code 25 - High temperature at manifold air temperature sensor OR Vacuum switching valve circuit open or shorted to ground OR High voltage at ATS sensor
2. Code 54 - Low voltage at fuel pump OR Low voltage at Fuel pump relay OR Output failure at quad driver module
Is there any way that these two are related to each other? I've never had of either of these before, so I need some help. Are these serious, as in don't take your car to the track Sunday or are they 'no biggie'.
Please someone respond ASAP!
KZad
Old Sep 13, 2002 | 06:15 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
Have you tried to reset your computer?? Is the car running different? Not sure what to say, just a couple of thoughts.
Old Sep 14, 2002 | 05:54 PM
KZad's Avatar
The car seems to be running just fine. I will try to restart the computer, and see if that helps.
Thanks.
KZad
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
86IROC112
Nov 27, 2015 09:54 AM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
