S/R Torquers/Compression Ratio?
Old Sep 13, 2002 | 05:23 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I'm planning on doing my cam swap in about two weeks and I recently came into some money so i'm going to do a 350 tbi intake ported with s/r torquer heads ported, and ported and polished on the exhaust side of the heads. My question is if I milled the heads down to increase the compression ratio would that work out well on a 305TBI?
Old Sep 13, 2002 | 06:11 PM
iroc22's Avatar
The S/R 305's already come at 58cc and that's gonna put you at your stock 9.3:1 ratio. What do you want to mill them for?
Old Sep 14, 2002 | 11:26 AM
Car: 89 Camaro RS
Engine: 305 TBI
I just heard if you mill heads a little it will raise the compression ratio. Wouldn't this help out?
Old Sep 14, 2002 | 01:44 PM
Silverado5.7L's Avatar
Arn't there extra thin gaskets you can use on the heads that would work like shaving metal, but you can go back later?
Old Sep 15, 2002 | 10:50 PM
iroc22's Avatar
Yeah you can use different head gaskets to raise the compression ratio and it is like milling the head. 9.3:1 ratio to me seems like the right ratio to run on the street because you can run like 8* advance and 87 octane without detonation.
Old Sep 15, 2002 | 11:44 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
FPP 1094 shim
Its got a .015 compressed thickness which will add to your compression. I had my vortecs (62cc stock) milled .020 and am running the 1094s. We put some "high tack" coating on them. No problem at all with sealing after 540 miles. I made a post about them a while back and poeple seemed to have good luck with them so I figured Id give it a try
InfernalVortex
Apr 20, 2021 11:31 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
TexasMaro
Sep 15, 2015 06:50 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
