deciding next mod...
Old Sep 14, 2002 | 05:05 PM
Rhoadster01's Avatar
I current have a 91 RS 305 TBI. My mods include a GM fastchip, K&N, headers, y-pipe, flowmaster, and posi 3.42's. My problem is i'm a college student on a tight budget and i'm not sure what mod to do next. Cams seem to be exceptionally expensive to have put in, I'm not sure if i should get a TC if i don't have a cam, etc. I might just put a small shot on and be done w/ it, but i like having my power all the time, not at a switch, ya know. Intake, throttle body? Help...
Old Sep 14, 2002 | 05:46 PM
NJ SPEEDER's Avatar
i don't see ultimate mods listed, do you have them? that is free stuff and shoudln't be over looked.
you may wanna look around for an edelbrock intake if you can save like $130 up. you can do the swap your self in a few hours with hand tools.
a convertor is a good mod too. teh stock convertor is horrible.
later
tim
Old Sep 14, 2002 | 08:57 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
NJ Speeder,
What will the ultimate TBI mods do to gas milage??
Old Sep 14, 2002 | 11:19 PM
Tim,
Two questions for ya. First, which stall speed should i go with. After that other posting, i was leaning towards getting the S-10 converter which stalls around 2200. But my car is my daily driver, so i wasn't sure if that would be overkill. And which of the intakes exactly do i want (part number, etc) thanks.
Donnie
Old Sep 18, 2002 | 02:55 PM
FLYNLOW92rs's Avatar
Edelbrock Intake #3704 is a direct replacement......Shop around for it though.....
You also may want to consider the MSD ignition cap/wires etc...., not too much performence, but it does help out....
Old Sep 18, 2002 | 03:34 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
S10 converter is a good choice for a mild car and you won't have any streetability problems.
The edelbrock intake would also make a decent addition.
Old Sep 18, 2002 | 04:16 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I agree with FLYNLOW92rs. Ignition is good for gas milage and will make your car run smoother. MSD dual connector coil will help you pull past 4,500 rpm as well, as that is where most stock coils tend to lose voltage output. It helped me out quite a bit, and for $40, it was probably the best performance for the money mod I've done. I didn't see an open element listed in you mods-which is also an inexpensive and easy mod.
Old Sep 19, 2002 | 09:03 AM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I would suggest going with the march underdrive pulleys and go get a cut out at the same time. I did the two the same day and felt a pretty big power gain. Our underdrive pulley is like a big bowl, the comparrison of the march pulley and the stock one is huge. All in all do all the bolt on's first then go to the intake and came. Heads would be the next thing afer intake and cam. Just IMO. With my mods in my sig I was in the high 14's. Thats in the 1/4 not the 1/8. I pulle 9.7 in the 1/8
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
