Is it possible?
Old Sep 16, 2002 | 07:48 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
Is it possible?
is it possible for my car to break 14.99 with just bolt ons?
Old Sep 17, 2002 | 08:06 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
From looking at your current et, I would think so. Headers and a stall converter will definetely help, and a posi in the rear could improve your excellent 60' time.
Old Sep 17, 2002 | 10:15 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Headers and a torque converter should get you a little more thant the .54 you need for 14's. Your converter stalls right around 1400. An inexpensive torque converter choice would be the 95+ S10 4.3L converter that stalls at 2000rpm. That 600 rpms should keep that car in it's powerband and allow for an even better launch.
Old Sep 17, 2002 | 10:59 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
defintly headers .. thats one of the bigest power gainers you can do for the 305 . it might be enough just with those but a 2000 stall would hurt either..
Old Sep 17, 2002 | 11:35 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
If headers and a TC don't seal the deal, you might wanna try Underdrive pulleys for a little bit more power. The Ultimate TBI mods will gain you some power as well. There's always some time waiting in suspension. You can still make a huge improvement over your E.T. by taking out the stock suspension and throwing in some polyurethane. If that doesn't work, nitrous bolts on quite nicely
Old Sep 17, 2002 | 07:04 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
can i put an newer S10 Torque converter in my car withput hurting anything or messing up the computer?
Old Sep 17, 2002 | 08:55 PM
RS92's Avatar
I know how you can get a 14.99 in your car..........LET ME DRIVE IT :rockon: with your mod's you should be there I think
Old Sep 18, 2002 | 07:03 AM
yeah the S10 converter is a bolt in deal and will run like stock just stalls 600 rpm higher. Computer doesn't care about the stall rating.
Old Sep 18, 2002 | 11:59 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Does that 305 use the GM 187 heads and the LO3 cam like ours did from the factory?
Old Sep 18, 2002 | 12:16 PM
JPrevost's Avatar
Car: 91 Red Sled
You lost me on this but I think you think that an s10 came with a 305. If that's the case, and I'm not saying it is, then my reply would be "never was a v8 in an s10." The 4.3L v6 uses the same tranny bolt pattern and the same tranny. The TC stalls for the v6 at the same speed as a thirdgen's stock TC stalls for a v8. Since the v8 has more torque it makes the v6 (s10) TC stall higher than rated. It's not enough to cause any huge problems with heat but I'd recommend a tranny cooler from any automatic SHO's (fits like a glove) and you can find them at junkyards.
14's with bolt ons and never lifting the valve cover is easy so long as you don't mind filling up the N2o bottle every once in a while. Seriously though, why WOULDN'T you want to dig a little deaper and do a cam swap? The next best thing is to get better heads but that costs a lot more.
Old Sep 18, 2002 | 04:29 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
J,
He said he has a crate 305, i was just curious if he got a long block or a short block and put his stock heads/cam on it...
Old Sep 19, 2002 | 09:15 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
yeah its got a brand new crate motor in it 3 year unlimited milege so im not going with internal mods for another 2 1/2 years
Old Sep 20, 2002 | 11:25 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
HEADERS TPI version, make sure they come with a 3" y-pipe
Old Sep 21, 2002 | 01:45 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
the s10 tcc has come up on the board before. its supposedly the same strength as the vette converter, yet had a higher stall speed. check around in some of the old posts, i thought i saw some more specs. it is a good idea, i was plannin on it til i ran outta money
