Oil Stains....
Old Sep 17, 2002 | 01:37 PM
Nitroburn's Avatar
Oil Stains....
Ok, I know this question is not a direct TBI related question and I don't see an area that this would fit in, however we have all experienced this: Parents getting mad, wife's getting mad, etc....
How in the heck do you get stains off of the concrete garage floor?!?!?!?
I have tried everything that I can think of. The last thing I just tried was using a pressure washer (rated at 2500 PSI). It did remove the surface layer but there is still stains.
Anybody have a solution that works?
Thanks,
Mike
Old Sep 17, 2002 | 01:47 PM
scauffiel's Avatar
I've had good luck with lacquer thinner, followed up with Coca-Cola. No kidding, Coke.
S.
Old Sep 17, 2002 | 07:35 PM
vrooom305's Avatar
since you're trying coke why not try crack:sillylol: j/j
but yeah coke sounds like a nice idea...
Old Sep 17, 2002 | 09:34 PM
JPrevost's Avatar
Car: 91 Red Sled
The cheapest cat litter you can get a hold of. Get a healthy amount and put on some sneakers cause it's time to dance. Just ground in the litter into the oil and it'll soak it up. Sweep it up to be recycled during the next oil change then vacuum.
Old Sep 17, 2002 | 11:56 PM
iroc22's Avatar
There's a product called "Oil Lift" around here and for the stains that have been set in for awhile, it usually removes them quite well.
Old Sep 18, 2002 | 12:14 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I uhh accidently spilled a lot of quarts of transmission oil on the garage floor when I pulled my engine and kitty litter cleaned it up. Ground it up, then let it sit for about 3 days and swept it right up.
Old Sep 18, 2002 | 07:57 AM
Nitroburn's Avatar
Kitty Litter - got plenty of that stuff. Fresh 'spills' I can get, it's those damn stains that have sat there for a long time soaking in.
Iroc22 - You say "OUT HERE". Where's that and does the company have a website or were do you by it?
Thanks to all you guys!!! (Now, maybe, I can calm the wife down a bit if I can get rid of these stains! It would be nice to sleep in the bed again instead of the dog house :lala: :lala: )
Later,
Mike
Old Sep 18, 2002 | 08:05 AM
fattie92's Avatar
why am i hearing wife, or mom in the same sentence as a garage?? we all know whos the ruler of the garage!!
Old Sep 18, 2002 | 08:11 AM
Nitroburn's Avatar
Well, yes... we do know who owns the garage. But when the garage is the primary entrance to the house and the first room you walk into is the kitchen, we know who owns that room and that's the first room that get's all the oil and grease marks from the shoes which, of course, was tracked in from the garage.
I swear, sometimes us guys can't win!!!
Old Sep 18, 2002 | 08:33 AM
fattie92's Avatar
...ahhhh i see, i dont have that problem. i have the problem of the garage being to full to get my car into and i work on it in the driveway and the driveway is all ****ed up from me now. my tranny desided to bleed out all its fluid onto it and im still trying to find something to get it out!!!
P.S!! DONT EVER EVER buy the concrete cleaner rom auto zone!!! it is the biggest peice of crap in the world. i was pouring it out and LEAVES fell out of the bottle!! they must have used leaves as a stuffer to make the bottle more full. i think the brand is "Coastal"
Old Sep 19, 2002 | 12:33 AM
iroc22's Avatar
It's in Canada. Not sure you if have it in Autozone or Pepboys and Im sure they dont have a website. There's other brands that do the exact same thing. Same **** different pile.
Old Sep 24, 2002 | 02:05 PM
BigMike1610's Avatar
Engine: 305 tbi=LO3
Transmission: Automatic
get a spray bottle and fill it with kerosene, spray on the spill and wipe it away or add kitty litter
Old Sep 24, 2002 | 11:17 PM
Kevin Johnson's Avatar
If you use a degreaser with a high pH it will saponify the oil (turn it into soap) which then can be washed away with water. High-pH-stable surfactants in the degreaser will allow it to wick down into the pores of the concrete.
There are products like this on the market, Purple Stuff or the Right Stuff are a couple names that come to mind. There are various oven cleaners too that are based on this idea. Make sure that you use eye and skin protection with this type of product.
You might need to repeat the treatment and always remember to try a product like this in a small inconspicuous area first.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
