TBI Time Registry: Report Your Times
Old Sep 21, 2002 | 03:36 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
As I notice everyone getting times and others asking about them, I've decided to make a spreadsheet outlining this. I will update it and post it on the web so that if anyone wants to know the capabilities of TBI we can direct them towards this. So without further adue please post:
Member Name
1/4 Mile Time (Altitude corrected would be nice, but if not then make sure to include your elevation)
1/4 Mile Speed
60'
Temp
Humidity
ATM Pressure
Method (G-tech, track, Tazzo etc.)
Mods Mods Mods and include engine size
Problems (crappy tires, bad spinning etc, you know, excuses )
Comments
Web Site
Any Dyno Numbers You have
This is mainly for Camaros but if you have a Truck or Caprice or whatever I can add you.
If you would like to see more catagories, I can add them, just Personal Message me.
Moderators, If you would like to make this a sticky that would kick a$$. Thanks all
Happy TBI-ing
Old Sep 21, 2002 | 05:04 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
Dennis 91RS
15.537
87.03mph
2.096
middle 80s
around 65%
dunno
Old Sep 22, 2002 | 01:28 AM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Fish89
14.989
92.35
2.280
80 something
dont know
bald tires, open 3.08 rear end
Old Sep 22, 2002 | 03:58 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Ok, I've got a few of yours just by looking through posts.
Here she is
http://www.geocities.com/machowalkclub/index.html
Old Sep 22, 2002 | 04:03 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Chuck!
15.500
92.81
2.412
70*
~30% humidity (perfect)
Track - Dragway 42
Fairly easy to see my problem Im workin on it though.
https://www.thirdgen.org/rides/index...ew&rideid=8662
Old Sep 22, 2002 | 04:32 PM
Slade1's Avatar
This was done yesterday at a rough 60% humidity with temps in the 80's...
Old Sep 22, 2002 | 06:23 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Now this is a good idea!:lala:
Old Sep 22, 2002 | 07:34 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
15.763 @ 87.22 mph
2.31 60'
85+ temp
FL 0 elevation
3.73 gears/posi, cat-back, 220+ H2O temps, K&N, 103K miles
Old Sep 22, 2002 | 10:03 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
wtf, I reply to another thread and it goes in here? hmm
Old Sep 22, 2002 | 10:25 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
MIne was at the track. I have intake, full exhaust, LT-1 cam. OPen element. afpr. pulleys. THats about it.
Old Sep 22, 2002 | 10:28 PM
Tacoma Boy's Avatar
Nate (Tacoma Boy)
13.24@98.1 mph
2.22 60'
decent weather at pacific raceway in kent, early september
Lots of tire spin
2.76 open diff
th700r4
I kick a_ _...
882 heads
no headers
hell no it aint stock
Old Sep 22, 2002 | 10:30 PM
Tacoma Boy's Avatar
Its so sleeper it looks like a wreck... wait a minute...dang.
Old Sep 23, 2002 | 07:03 PM
Mutiny32's Avatar
Best time to date in the car, made run yesterday
R/T .598
60' 2.391
330 6.756
1/8 10.352
MPH 68.45
1000 13.454
1/4 16.084
MPH 84.87
cut off 4/10th's of a second just by getting a new tranny shift cable.:lala:
Old Sep 23, 2002 | 07:20 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
PUT YOUR MODS IN THE POST PLEASE!
Thank You
Old Sep 24, 2002 | 05:47 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
It might also be useful to add:
engine size (305 or 350 cid)
fuel delivery (TBI, carb etc)
track altitude, above mean sea level
Old Sep 24, 2002 | 01:01 PM
dreamsbird's Avatar
r/t .720
60' 2.083
330 6.246
1/8 9.747
mph 68.34
1000 12.779
1/4 15.340
mph 89.88
temp 83
humidity 67%
track
problems: didn't use tcc lockup switch and was running a tad lean up top
Old Sep 24, 2002 | 01:59 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
This is mainly for Throttle Body Injected Camaros (I could add a spreadsheet for Caprice's and Trucks though). The engine size thing is usually included with the mods but I will add a column for that just because the mods column can be a little tough to read. I'll add in elevation as well.
Old Sep 25, 2002 | 01:01 PM
Eric 91RS's Avatar
Car: 92 Chevy 1500
Engine: 350 TBI
Transmission: TH-700R4
i haven't been on here in about a year. I still cant find time to post
here are my times
91 RS 305TBI 700R4
best time15.86 at 86 MPH
cant find that slip
this was the pass before it though
60' 2.313
1/8 10.284
1/4 16.045
MPH 85.14
Stock w/ open element and ultra flow muffler(junk) not cat back
transmission slips bad does not shift to third past half throttle i turn 6300 rpm in the traps with the shifter on od 2.73 gears
the RS is retired untill i swap in LT1 4L60E
i currently run a 64 Nova w/ 383 :hail: 11.26 best et at 117 mph
i love torque i may put the 383 in the RS
we also have a bone stock 93 GMC ext cab 350 auto 17.175 et
Old Sep 25, 2002 | 01:25 PM
Mutiny32's Avatar
R/T .598
60' 2.391
330 6.756
1/8 10.352
MPH 68.45
1000 13.454
1/4 16.084
MPH 84.87
Sorry, SLP ceramic coated 1 5/8" headers w/AIR
Catco Direct Fit 3" cat w/AIR provision
Hooker 3" catback
Taylor Spiro-Pro wires
Open element air w/K&N
That's about it...
Old Sep 25, 2002 | 02:06 PM
wh0di's Avatar
15.223 at 90.07
3.42 gears/ SLP posi
open hedman shorty's with Y-pipe ... nothing else
shiftkit
open element 10x 2.5
Old Sep 25, 2002 | 05:46 PM
Tacoma Boy's Avatar
Originally posted by Tacoma Boy
Nate (Tacoma Boy)
13.24@98.1 mph
2.22 60'
Lots of tire spin
2.76 open diff
th700r4
I kick a_ _...
882 heads
no headers
Ok, heres the deal. I don't like giving it away, but here ya go. A mild TBI 350 backed by a TH700R4 with a 100 shot puts me in the low 13's. Its not a high revving motor either, I leave it in drive at the strip. The engine has hyperetic pistons, a dual pattern cam with less than .500 lift, much less actually, retarded 6 degrees. An edelbrock intake with the stock TBI modified with larger injectors sits on top of the 2 bolt main block. The reciprocating assembly is balanced. Stock 882 heads hold everything back, and empty into ported stock manifolds leading to a performance cat and a flowmaster 80 series cat back my dad put on. I wish i could try the hooker aerochamber muffler, but the flowmasters sound great. A NOS EFI system provides spray. The chip is a one off piece. The 700R4 has syclone internals and converter, and shifts HARD. Under normal driving the 1-2 shift occurs at 3700 rpms. Kinda hard to be quiet. it stalls a few hundred higher than stock. I love my car, but now its out of service. I got hit by a woman in a minivan, punishing the passenger side. It was totalled, but with less than 4000 miles on the new engine, and the trick shifting automatic, i couldn't let it go. I had to sell the NOS system and the T-Tops to pay to fix the suspension when i bought it back, it now is considerably slower. I ended up selling it to my dad for an unspecified ammount of help and money to get the cutlass back on the road by the time I get my license back in june of 2003. At least its still in teh family. : (
Old Sep 25, 2002 | 06:39 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
It just keeps growing and growing...ahhh
keep em' comming, it's really cool to see all the times listed!
Old Sep 29, 2002 | 03:33 AM
vjo90RS8's Avatar
Car: 2002 Z28
lost my timeslip, but hes what i remember
60' 2.240 (no traction problems)
1/4 15.970
Old Sep 29, 2002 | 01:41 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
hey dude your link doesnt work!
Old Sep 29, 2002 | 09:13 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Ah, I hate Geocities, I'll see what I can do
Try this the link in my sig now
Old Oct 1, 2002 | 05:54 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
Hey Dennis91RS, you stole my avatar
but i guess you can use it
Old Oct 1, 2002 | 07:02 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
that avatar kicks *** but how comes mine doesnt move any???? i can't stand hondas and havent lost to one yet just ask my friends on the board i go to the track with
imports slayed
-early 90s prelude
-early 90s CRX (completly stripped out)
-honda civic hatch back new style with GSR motor(whatever that is)
-Nissan 240 SX
-Nissan Maxima
-Riced out Nissan Pickup
-Toyota Camry
-early 90s Honda Accord
-early 90s Acura Integra (2 of those)
-oh and if it counts a riced out 95 Ford Taurus
Old Oct 1, 2002 | 07:15 PM
Car: 2001 Camaro SS
Transmission: A4
imports slayed
-early 90s prelude
-Nissan 240 SX
-Nissan Maxima
-Toyota Camry
All imports blow, thats why I made the avatar I've had to drive a few honda 4 bangers... and those are the slowest piles of gay I have ever had to sit in
you saved it as a jpg file... in order for it to move it needs to be saved as a gif file... btw, nice kills
Old Oct 1, 2002 | 08:43 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
thnx a lot
btw i don't street race all those kills were done the right way
heads up racing at the dragstrip
Old Oct 2, 2002 | 01:38 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Anybody else have anymore times??
Old Oct 2, 2002 | 07:39 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Axoid
R/T .649
60' 2.114
330 6.215
1/8 9.607
MPH 72.81
1000 12.534
1/4 15.006
MPH 91.27
Temp ~85
Norwalk Speedway 9/30/2002
3.42 gears, Hooker headers and cat-back, high flow cat, K&N filter, Stock air cleaner with K&N xstream lid, march underdrive pullies.
Had some traction issues. The car is set up for autocross and I was running 2 year old Goodyear GSCS road race tires on the
rear.
Dynoed 9/28/2002 181rwhp 270rwtq
Old Oct 4, 2002 | 12:37 AM
89rskelly's Avatar
my 305 1/4 time
ive got an 89 rs, 305, TBI, 2:73 gears, open ended rear, ****ty *** pep boyz tires...
89rskelly
time: 15.841
r/t: .505
speed: 86.15
60 foot: 2.232
temp about 65-70 degrees
humidity 99 ( dont know if thats rite, it says that though)
this was at ATCO nj
MODS ....
3 inch cat back american thunder flowmaster exhaust, full tune up with 8.8mm wires ( lol), all new sensors, like temp sensors, new sensor turns fan on at 170, 4 inch cowl hood, A LOT of new random parts (brakes, shocks, hoses, radiator, fan motor, headliner, cat, starter, fuel filter ect.)
as of today october 4th my car now has richmond 3:73 gears and a moroso posi rear ... its still at the shop i have to pick it up tomorrow before work hehe, cant wait to see how the gears are! and in 2 weeks my headers are gettin put on also i put a chip in but that was just the other day, i havent ran it yet like that
Old Oct 4, 2002 | 08:31 AM
JPrevost's Avatar
Car: 91 Red Sled
13.8 @ 102
330ho crate motor (vortec heads), 212/222 .435/.460, RPM intake, adaptor plate, Holley 670, at the time a stock cop car eprom, SLP try-y headers, !cat, Borla adjustable but at the time it was a Summit brand muffler, 3.73 posi, full stereo/interior, setup for street (lowered, 245/50's, big sway bars, STB), Alston SFCs, and 3/4 tank of 89.
Now I've got a 2800 stall converter but am having troubles hooking up. Still getting 2.1_ 60' times with the 245/50 tread. I definatly need more tire and those LCA rel. brackets.
Old Oct 4, 2002 | 03:30 PM
NJ SPEEDER's Avatar
Nate (Tacoma Boy)
13.24@98.1 mph
2.22 60'
Lots of tire spin
2.76 open diff
th700r4
I kick a_ _...
882 heads
no headers
nate, can you post the rest of this slip please. the numbers don't seem to add up right. to run a 13.2 at only 98mph you woudl have to cut a low 1.7 60ft at least or you woudl have to be well on your way to a 115mph trap speed and lift very early.
please explain.
later
tim
Old Oct 4, 2002 | 07:17 PM
deadtrend1's Avatar
Deadtrend1
1/8 : 10.008
speed : 70.55
1/4 : 15.495
speed : 90.20
60' : 2.332
Temp : HOT id say 90*
E-Town NJ
Mods : In the sig
Problems : Lame 215 tires, which did nothing but at the line.
Comments : See what happens after my cam swap
Old Oct 4, 2002 | 10:38 PM
Nasty_Bird_'90's Avatar
In the sig. I know....sux. Oh well. Better times with the LS1 next season!
Old Oct 6, 2002 | 10:40 AM
RareSUV's Avatar
Re: TBI Time Registry: Report Your Times
1/4 Mile Time : 13.681
1/4 Mile Speed: 92.86
60': 1.820
Temp: 55
Humidity: n/a
ATM Pressure: n/a
Place: Atco Raceway
Mods Mods Mods: 100% Stock from factory, 69,000 miles
Comments: Dunlop street radials, 44psi
Old Oct 6, 2002 | 05:01 PM
1989camarorsrs's Avatar
Re: Re: TBI Time Registry: Report Your Times
60': 1.820
Temp: 55
Humidity: n/a
ATM Pressure: n/a
Place: Atco Raceway
wow what car are u driving
Old Oct 6, 2002 | 05:14 PM
RareSUV's Avatar
Re: Re: Re: TBI Time Registry: Report Your Times
not a car, but a truck, hence my name RareSUV
Old Oct 6, 2002 | 05:28 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
How rare an SUV is this? Whatever you're smoking pass that $hit over here!
Old Oct 6, 2002 | 05:45 PM
RareSUV's Avatar
well, they only made 2200 of them in '93, and looks like this,
oh yeah, and I dont smoke
Old Oct 6, 2002 | 05:51 PM
  #42
TonyC's Avatar
Car: A Camaro
Engine: Weak
Oh hehe, that makes a little bit of a difference! Are Typhoon's throttle body injected? Stock Boost? I tried to race a Typhoon once....I lost by just a little....OK OK I got slaughtered.
  #43
NJ SPEEDER's Avatar
rare suv, that woudl be a ty, and it is sfi, not tbi. so yer time doesn't really count for this registry.
it is a cool whip though
i always wanted to get a cyclone and take off teh ground effects and put it up to normal ride height so it just looked liek a normal black s-10
later
tim
Old Oct 6, 2002 | 06:03 PM
  #44
RareSUV's Avatar
later
tim
actually, its CFI, not TBI or SFI. yeah, i know it dont count, but someone else i know posted in here, so i figured i would have some fun
and thats Syclone
yeah, a few people have attempted the "normal" truck look, but you cant achieve the results, cause you need to install 4x4 rims also, and with 4x4 rims come skinny tires, skinny tires = less traction.
TonyC, yes my run was stock boost, 100% stock truck, stock chip, turbo, trans, motor....actually, my intercooler wasnt working at the time either, so i could have went faster.
Old Oct 6, 2002 | 06:10 PM
  #45
89rskelly's Avatar
LOL
yeah silly ur not alloud to post ur times in here hehe ... ur not special like US with tbi's HAHA
Old Oct 6, 2002 | 06:13 PM
  #46
RareSUV's Avatar
Re: LOL
hey, I used to have a Crossfire Injected 3rd Gen Leave me alone ...haha
Old Oct 7, 2002 | 08:48 AM
  #47
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
92 LO3
150,000 miles on car, motor has never been out
weight- 3400
time- 15.4
speed- 90mph
60ft- 2.24
water temp- 150*
track conditions- night, sea level, 59*, Cecil County, Maryland
removed air cleaner at track, Pep boys 225/60/16 tires, 2000rpm TC, B&M $hit kit, 3.23 posi, 350 injectors at 12psi, Jet stage II chip, underdrive pulleys, edelcrock intake and T.E.S., 1.6 rollers, 2.25" pipe after cat with no muffler, just resonator. Experienced lots of wheelspin.
MustangBeater20
Oct 29, 2022 09:20 PM
Thirim
Aug 9, 2015 06:19 PM
