backfireing with cam swap
Old Sep 22, 2002 | 09:20 PM
bandit45's Avatar
Alright I'm backfiring and not starting it gets really close but doesnt quite make it. So what did I forget about? I have my timing set at 4* and sure that the timing chain is right. Help me out guys this is frustrating as hell
Old Sep 22, 2002 | 09:48 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
sounds like it is in the timing
Old Sep 22, 2002 | 11:09 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Don't know what kinda cam you put in it, but generally cam with more duration like more timing. Either that, or your vavles are too tight when you put them back on.
Old Sep 22, 2002 | 11:11 PM
nice avatar
Old Sep 22, 2002 | 11:13 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Originally posted by brodyscamaro
nice avatar
Can't imagine why you would say that
Old Sep 22, 2002 | 11:38 PM
mylittlemule's Avatar
Car: 87 Wrangler
Engine: 355 TBI
Sounds like the distributor might be 180 off. The same thing happened to me and i just re stabbed the distributor ro solve the problem.
Old Sep 24, 2002 | 02:33 AM
alohamike's Avatar
When you changed timing gears did you change both gears? It sounds weird but, if you only changed the camshaft gear, you may created a problem with the relationship between old gear and new gear.
Old Sep 24, 2002 | 07:01 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
It is generally the 180 degrees off problem. Valves being to tight can cause it too. I have done both.
Old Sep 24, 2002 | 10:55 AM
Car: 87 Wrangler
Engine: 355 TBI
i can also vouch for the valves being to tight and shooting flames thru the throttle body.
Red iroc-z 305
Sep 30, 2015 05:22 PM
Cameeeero
Sep 18, 2015 04:00 PM
dyeager535
Aug 28, 2015 08:10 AM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
