An SS hood on a 92 TBI
Old Sep 30, 2002 | 04:29 PM
samdog1232000's Avatar
Car: 92 RS 25th Anniversary
Engine: 350 L98 w/Vortec Heads
Transmission: 700 R4
I am searching magazines frantically to find an air box that will work on a 92 camaro RS that has TBI. Is there any companies that make an air box that will make my new SS hood functional???????? PLEASE HELP ME
Old Sep 30, 2002 | 05:20 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
no that i have found yet.. your best option is to make something your self.. thats what i plan to do once i get the hood.. .
Old Sep 30, 2002 | 06:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
since nobody makes an airbox just go ahead and send me the hood
Old Sep 30, 2002 | 11:14 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
NO ME!!!!!
AJ
Old Oct 1, 2002 | 04:54 PM
NJ SPEEDER's Avatar
if you have a flat base open element you are already half way to having a really simple and functional box for it.
simply make a square off of the base that is a little wider and a touich deepr than the scoop opening. cut a hole out of it that is a little bigger than the raised spot in the base that clears the throttle linkage. than simply pop rivet the square to the bottom of the open element. now get some foam and make walls at teh edge of the square(glue foam to new wider base) that will be tall enough to touch the hood when it is closed.
then just install it like you did before. the stud and element you used before will be enough to hold it on firmly and level. the foam will also allow for the engiens natural movement when you hit the gas.
later
tim
Old Oct 2, 2002 | 06:48 AM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
http://www.ramairbox.com Here's a few parts that might help.
Old Oct 10, 2002 | 01:43 PM
I just want a hood that is functional. I know there is someway to do it or buy something. I just dont want it to be a crappy setup.
Old Oct 13, 2002 | 01:39 PM
FLYNLOW92rs's Avatar
They don't sell kits, which means you gotta get creative and make one..........
Old Oct 13, 2002 | 09:45 PM
Black_Widdow's Avatar
Car: 05 GTO, 88 GTA, 98 SS
later
tim
Would this be bad weather (rain) friendly? Wouldn't you have to make some sort of route for the water to get it away from the air cleaner or worse yet the throttle bores? I would like to try this but it seem s like a pain in the a$s
Old Oct 13, 2002 | 11:47 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I think GTA automotive (sponser at top of page) sells a ram air box. It says for TPIs only, but with a little extra work you could use it. Really, all you would need to do is this: Use a Caddy air box, like CHEVYTOWN is using on his truck. Then measure out where the ram air bow needs to go. Then, use PCV pipe or something of that sort of proper diameter, cut to proper length and secure it. You may need to fab a bracket for the air box, but that should be pretty easy to do. I think the ram air box kit sells for $180 w/ k&N.
As far as the rain thing goes, I don't know. You could try to email GTA Automotive, and see what they say. Good Luck!!!
Old Oct 16, 2002 | 07:29 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Most guys use something like this, square or round.
Ithink this is something like NJS is talkin' about.
Hotrodboba400
Dec 10, 2019 07:07 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
