Tpi Pump
Old Oct 20, 2002 | 06:18 PM
Mike1's Avatar
Tpi Pump
I've been doing searches on this and see the walbro 255 pump recommended, but would a stock 5.7 tpi fuel pump be able to support 350hp with tbi? If not why and do I need the 255 to be able to reach my hp goal? Mike
Old Oct 20, 2002 | 07:05 PM
deadtrend1's Avatar
they might be a little too much for fuel pressure. Stock tbi's run around 11 PSI, TPI pumps run around 45 PSI.
Old Oct 20, 2002 | 09:32 PM
Mike1's Avatar
From what I've been reading it shouldn't cause fuel pressure issues, but will it flow enough for 350hp?
Old Oct 20, 2002 | 10:15 PM
JPrevost's Avatar
Car: 91 Red Sled
Why do you need/want to know? The walbro pump is only $100, unless you get a free TPI pump it's still not worth putting in. The TPI pumps can support a decent amount of power just like a stock TBI pump can support about ~280hp at it's limits. TPI might be a little more, not sure though.
If you're making 350hp which is more than me then get the walbro. I have to get one because this stock pump can't support 18psi, 3rd gear, 3000rpm and climbing under WOT, else I would tell you the stock pump is probably enough .
Old Oct 21, 2002 | 07:01 AM
Mike1's Avatar
Thanks, wheres the best place to get one? I see summit only carries the Holly, which is the same but cost more.
Old Oct 21, 2002 | 07:38 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Pump is $93 here
http://www.autoperformanceengineering.com/
TPI pumps work fine in TBI cars the pressure regulator is not built into the pump so it maintains TBI pressure.
Old Oct 21, 2002 | 11:10 PM
JPrevost's Avatar
Car: 91 Red Sled
Originally posted by brharris27370
Pump is $93 here
Good site! I had it bookmarked but I lost it during a format and reinstall of windows 2000.
The TPI pumps will work fine in TBI cars except that they also won't support 350hp unless you're one of the lucky few.
Old Oct 22, 2002 | 05:28 AM
Mike1's Avatar
Couldn't get through to thaat guy, so ordered from JD's Perfomance they were out of the walbro 255ltr so I got the 190ltr this one should support my goal hp level shouldn't it--cause I need the pump asap.
Old Oct 22, 2002 | 12:35 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
www.racetronix.com
Kat
Grant2k
Jul 10, 2018 04:01 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
