Gettin Hot under the Collar
Old Oct 28, 2002 | 11:04 PM
Silverado5.7L's Avatar
I'm going to put a TBI spacer atleast 1" tall. I'm going to remove the collar that is between the TBI and the Aircleaner housing.
There is a hose that runs to the driverside valve cover.
Can I just put a filter in the hole on the valve cover? Is there a better way like cutting a hole in the filterhousing and putting the hose there?
Old Oct 29, 2002 | 02:13 AM
JPrevost's Avatar
Car: 91 Red Sled
That is your PCV system and yes you can just put breathers on the valve covers. It's odd that on an f-body the PCV goes into the TB just above the blades yet with the trucks they use that spacer ring, go figure.
Old Oct 29, 2002 | 10:44 PM
There is a pcv on the pass side that goes to the TBI, below the blades. The other is from the drivers side. and goes to this collar. I was under the impression from a post in the archives that all the TBI's had them. Guess not.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
