Roller Rockers
Old Oct 29, 2002 | 10:20 PM
chevy8ford's Avatar
Car: 88 Firebird
Roller Rockers
Has anyone used roller rockers on their car? I want to see if they are a viable option, i will be puting in an lt1 cam and an edelbrock intake, should i get 1.5 or 1.6? or a combo? Any brands to steer clear of? any particular thing i need to know about putting them on the 305?
thanks
Old Oct 30, 2002 | 10:38 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Be careful of the 1.6 ratio with lt1 cam on stock heads. Stock heads max out at about .480" lift. lt1 would be around .490" lift with 1.6 rockers.
Don't buy the cheapy $150 roller rockers. Several people on this forum have complained about them wearing quickly and breaking. You would need the $300 set of self aligning rockers and that much money would be better spent on other areas of that engine to make more HP.
Old Oct 30, 2002 | 05:24 PM
chevy8ford's Avatar
Car: 88 Firebird
What about the comp cams magnum, roller tipped rockers? or would i still be better with the full rollers? from crower, who are local, or crane?
Old Oct 31, 2002 | 06:59 AM
I feel that on stock heads your money would be better spent on buying new heads or other mods. You won't gain that much hp off of rockers. $$ to HP ratio is to high.
Old Oct 31, 2002 | 08:45 AM
chevy8ford's Avatar
Car: 88 Firebird
oh, also i was thinking of using the vortec heads, milled of course, or maybe the sr's for the 305 from world products. Any other ideas?
Old Oct 31, 2002 | 11:29 AM
Vortecs have the same .480" lift limitation so unless you have more machine work done then you are still stuck with 1.5 rockers. The world torquer heads can run over .500" lift and then you could use the 1.6 rockers and squeeze more hp out. Whether its worth the cost or not has been debated on here many times.
I would say that if you are going from 1.5 regular to 1.5 roller the cost isn't worth it but to go from 1.5 regular to 1.6 roller then you will gain some lift and would be closer to justifying the cost. I have run the 1.6's and couldn't tell the difference. If the heads flow substantially more at the .490" lt1 with 1.6 rr instead of the .460" stock lt1 lift then it should make enough power to notice.
Old Oct 31, 2002 | 03:08 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Another note.....
Don't waste your money on getting arms with roller trunions. A stamped steel roller tip rocker arm like Comp Cams Magnums are fine. There are a lot more headaches involved with full roller rockers than there is HP to justify spending the money on them and dealing with the accelerated wear time.
FYI, I've had two cars that both had full roller aluminum rockers. One set was Crane Gold, and the other was Harland Sharp. They both looked great, and perhaps did help a little on both engines they were on (400HP), but not enough to justify what I spent on them. Plus both cams were solid, so full roller was the only way to get true accuracy out of them. Not needed on a hyd. cam.
AJ
Old Nov 5, 2002 | 07:04 AM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
i was reading in a super chevy that they threw S/R torquers on a 400 small block (mighty mouse) and lost hp b/c cause as they claimed "they flowed to well" - what do u guys think?
Ty
I'm stickin' w/my truck castings anyway! lol
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
