Heads
Old Oct 30, 2002 | 09:52 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Heads
Anyone know much about a set of 293 casting heads? They came off of a 327 out of a 1968 Impala.
I know they have 75cc chambers, 1.72 Intake, and 1.50 Exhaust. Would these work on a 305 at all or atleast better than the stock swirl port heads?
Or would it be better to just clean up the 327, and throw the entire motor into the car. I know I would like to do the motor swap but if swapping the heads on to my existing motor would work, I could do that until I get the 327 cleaned up and tuned and can swap it in.
Lemme know what ya think.,
Old Oct 30, 2002 | 10:56 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I don't think those heads will work on a 305. If you don't have a problem with the valves fitting you'll have a problem with compression. Stock 305 heads are like 58cc chambers, so going up to 75cc chambers will be a big jump (considering the compression is only 8.6ish to start off with). Besides I think the 305 heads have 1.84/1.5 valves in them.
Old Oct 30, 2002 | 11:39 PM
iroc22's Avatar
Don't waste your time with those heads. They're junk.
Old Oct 31, 2002 | 05:32 PM
Nitroburn's Avatar
I thought the 305's had 9.3:1 compression?!?!?
Old Oct 31, 2002 | 08:12 PM
iroc22's Avatar
All L03's have 9.3:1 compression.
Old Oct 31, 2002 | 11:23 PM
kfoley's Avatar
Car: '85 Z28
Sorry about the confusion, the LG4's had 8.6
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
