HeLP with 89 rear END!!
Old Nov 8, 2002 | 11:29 PM
89RS03's Avatar
I have an 89 RS Lo3 A4 and im pretty sure my gears in the rear are 2.73 and i was wondering if anyone has 3.42s nows. And like what did u buy and about how much was it? And i have no clue how many splines my rear axle is?
Old Nov 9, 2002 | 04:07 PM
1989camarorsrs's Avatar
Hey whats up man, i got an extra set of 3.42s for a 2 series carrier 3.08 and numericaly lower if u need them. There brand new from summit(richmondgears)
Theyd fit perfect, reason i have them is cause i decided after i purchased them that i wanted to get the 3 series gears and a 3 series carrier. Give me an email if ure interested im at camaroz4lif@yahoo.com
Old Nov 9, 2002 | 08:36 PM
CC's Avatar
CC
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
I have a 1989 RS TBI auto that had a 2.73 non posi. I bought the whole rear end off a 1986 IROC w/3.42 disc w/proportioning valve for $200. The difference is 0-60 8.5 sec stock with 2.73 and with the 3.42 0-60 is 7.3 @ 15.49 quarter mile sec via G-tech. Of course hypertech chip, March pulleys, TBI spacer helped as well. But the engine is stock otherwise. No headers, no cat-back, head and the intake never touched. The project took 4 hours with 2 people, regular tools and long shower afterwards. 3.42 off the IROC made a big difference.
Old Nov 10, 2002 | 12:29 AM
89RS03's Avatar
Hey CC did u get posi or what and if u didnt how much wheel spin do u get when u take off?
Old Nov 10, 2002 | 01:10 PM
CC's Avatar
CC
Hello, yes it is posi and I do get some wheelspin.
When I tested it with a G-tech I had to ease on the gas and
then mash it all the way by second. What mods do you have?
Old Nov 10, 2002 | 01:12 PM
since u changed ure gears, have u fixed ure speedometer cause mine is off since i got the gears swapped. If u havent does this affect the g tech at all.
Old Nov 10, 2002 | 01:19 PM
89RS03's Avatar
How hard was it to take off the old rear end and swap it??? Do u need any special tools?
Old Nov 10, 2002 | 04:18 PM
CC's Avatar
CC
Yes you are right my speedo is 5mph higher than usual that hasnt been fixed, however this doesnt effect the G-Tech operations at all. For the tools, make sure you utilize two jacks and two jackstand, a can of WD-40, breaker bar, standard tools (power tools even better to speed time and convience). Please take caution because the whole rear end is heavy.
Old Nov 10, 2002 | 05:24 PM
But doest the g tech go by the speedometer readings. LIke when the speedometer hits 60 itel stop the time. How could just the gtech know how fast the car is going.
Old Nov 11, 2002 | 09:20 PM
racereddy20's Avatar
it uses the inertia of the vehicle to calculate how fast the car runs through the quarter mi. It never hooks up to your speedo. You just hook it up to the windshield and plug into the cigarette lighter. It has a display and you have to zero it out. After you zero it out you push and hold the go button (dont really know what button it was my friend was doing all the button pushing.). Then you go and itll let you know when to stop. Its usually off on the mph though by about 5-7 MPH too fast.
Old Nov 11, 2002 | 09:21 PM
btw I did it in about 7 hours by myself with hand tools and 3 jacks. Did it again with air tools and finished in about 4.
Old Nov 13, 2002 | 03:41 PM
Formula4Phil's Avatar
rear from irock
cc-
did your 89 rs have rear disk brakes prior to axle swap- if not what was needed to adapt the rear wheels ect?
Old Nov 13, 2002 | 07:10 PM
CC's Avatar
CC
The 3.42 disk rear end was purchased complete with axles, brake pads, calipers and rotor as well as sway bars, sway bar links, springs. Also the proportioning valve was included off the IROC. Then you must bleed the brakes really well otherwise its all go and no stop.
Old Nov 13, 2002 | 08:51 PM
89Irocz23's Avatar
I have a 9 bolt 3:23 posi rear end with disc brakes for sale. PM me and give me a offer and ill proly take it.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
