Questions with install.
Old Nov 9, 2002 | 06:09 AM
beamar's Avatar
K, I have my heads all ready and start to yank off the old junk.
I have a set of headmen headers with Y-pipe I'm going to use for now. Since there is no AIR lines for them, So I do away with all my emissions junk under the hood? What do I do about the smog pump?
My new cam isn't a roller, Do I still need to use that valley piece that goes over all the lifters?
The heads I'm using are 350 center bolt heads. I bought a set of 1.6 roller rockers from a friend. I forget if they are self alining or not. Either way he said they were the ones that NEED to be used with guide plates. Needless to say I don't have guide plates or intend to buy and install them, will they be fine?
How is my stock computer going to do for now will all the mods listed below? Will it run ok intil I get the stuff to make my own chips?
Centerbolt 350 heads - ported and polished. Milled for extra compression.
Performer Intake
Holley 670
Headman heads and Y pipe
Flowmaster 3" cat back
Crane Cams non-roller Hdy. 454/454 218/218
Summit 1.6 Roller rockers.
.530 lift dual springs
160 thermo
timimg @ 14°
thats about it....
Old Nov 9, 2002 | 06:16 AM
beamar's Avatar
Vendor: Summit Racing Equipment
Product Line: Summit Steel Roller Tip Rocker Arms
Material: Hardened Steel
Horsepower and durability
Small Chevy: 1955-87 262-400, 1.6 ratio, 3/8 in. stud rockers
Get the horsepower and durability you want at a price that suits you with this set of roller tip rocker arms from Summit Racing. Formed from heat-treated steel with a long slot design and precision ground rollers, these rockers will deliver the performance you're after--even in high lift applications. Each set includes rocker arms, grooved rocker *****, and nuts.
Sold in sets of 16.
that's all the info on can get on the rockers....
Old Nov 9, 2002 | 06:30 PM
beamar's Avatar
They are Non-self-aligning.
The heads I'm using are from a 96 350 with centerbolts. THey aren't LT1's, just standard centerbolts.
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
formula_novice
Aug 18, 2015 08:48 PM
redmaroz
Aug 16, 2015 11:40 PM
