WinALDL question
Old Nov 13, 2002 | 01:16 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
WinALDL question
Can I use WinALDL to adjust my TPS? It's currently reading -2% when it should be at zero. I know WinALDL monitors it as that is where I got the info from, and there is a tech article on how to adjust the TPS on this page. But my labtop took a crap, and I'll have to use a friends. So I was just wondering before I went and bugged him for his computer, or will I have to use a VOM? Thank you in advance.
Old Nov 13, 2002 | 11:56 PM
Engine: LO3;383tpi
Just to clearify, can I use the data that shows up on WinALDL to adjust the TPS? Or does the engine need to be running for readings to appear?
Old Nov 14, 2002 | 12:46 AM
JPrevost's Avatar
Car: 91 Red Sled
Winaldl shows you voltage. Just use the voltage to make sure your TPS is in range, if it is, just configure winaldl to show your TPS voltage at 0% and the WOT voltage can be input into configuring for 100%. It's not a big deal so I wouldn't bother if you're only at -2%, that's nothing, just check you're getting enough volts with your foot on the floor.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
