Which one of these three cams
Old Nov 15, 2002 | 05:27 PM
boogie's Avatar
350 TBI truck,stock prom,edelbrock tbi intake, crappy 193 heads with bowl porting and a three angle valve job, H345P speed pro hypereutectic flat top pistons,3inch single cat back system, 4L60E and 3.42 gears. Converting over to factory hydraulic roller.
ISKY 257/265 209/217@.050 .465/.485 lift overlap 37 112 LSA
I really like this one but the 193 heads probably would not benefit from the higher lift, also look at the intensity, it is 48, that is a very quick opening,thats good for power but maybe a little noisey. What do you think?
CRANE 264/270 208/214@.050 .438/.452 lift overlap 43 112 LSA
Looks pretty good to me as long as i dont lose any bottom end.
COMP 258/264 206/212@.050 .480/.488 lift overlap 37 112 LSA
As you can see, these cams are very simular and pretty mild for a 350. This truck is heavy and low to mid range power and torque is the primary goal.
Thanks for your input
Old Nov 16, 2002 | 02:37 PM
305TBI's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Axle/Gears: 4.10
Boogie,
Your heads have been modified, so they should flow better than stock. I like the Iskey cam specs. The intensity is better than many cams and will get air/fuel mixture into the combustion chambers faster. The 112 LSA will give you a nice idle.
Good luck,
Don
Old Nov 16, 2002 | 04:05 PM
NJ SPEEDER's Avatar
i liek teh isky and the comp. teh comp looks liek it woudl idle a little smoother, but teh isky looks liek the power maker
good luck
later
tim
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
