When I reverse, the car stalls
Old Nov 17, 2002 | 12:28 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Sometimes, when I reverse out of a parking lot, the idle like dissapears almost, and the car will just stall. Ill step on the gas and slowly reverse out, and then boom, it just stalls. Has this happened to anyone before? I have a 3 inch flowmaster dual exhaust. Is it air going back into the pipes the opposite direction thats doing it, and creating a vaccumm which creates a stall or what?
It is very annoying. Stock exhaust is angled down towards the ground, and I dont recall that happening when I had that. But is this **** normal, because its annoying me.
Old Nov 17, 2002 | 12:29 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Its a 305 TBI 1991 RS btw, hence the thread here.
Old Nov 17, 2002 | 01:10 PM
vjo90RS8's Avatar
Car: 2002 Z28
this happened to me the other day, i was backing out of a parking spot, tapped the gas lightly and the RPMs went up slightly and then dropped to about 350-400 and stalled. But i dont know the reason for this.
Old Nov 17, 2002 | 06:52 PM
JPrevost's Avatar
Car: 91 Red Sled
Running lean, hook up a scanner and check out the BLMs during normal driving. Change fuel filter, check pressure and replace pump AFTER you've made sure your regulator is still good.
Old Nov 17, 2002 | 09:41 PM
dunerida82's Avatar
Car: 1991 RS
Engine: 305 TBI
Both fuel filter and fuel pump are brand new. I had that situation about a month ago.
Old Nov 18, 2002 | 12:25 AM
JPrevost's Avatar
Car: 91 Red Sled
Hook up a scanner and drive around. See what your BLMs are at.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
